How to remove
TomReilly
PostPosted: 16:56 - 17 Oct 2013    Post subject: How to remove Reply with quote
Exhaust rust.
I have no fancy liquids or cleaners at the moment and no money to buy any till the end of the month.
Any house hold cleaners or techniques to remove it?
Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. Wink
DrDonnyBrago
PostPosted: 16:59 - 17 Oct 2013    Post subject: Reply with quote
Wire brush.
If it is a stainless steel exhaust with rust spots, use brick acid and wire wool/brush.
If it is a mild steel exhaust, wire brush then paint it. BBQ paint seems to work well.
Quote Me Happy
PostPosted: 17:01 - 17 Oct 2013    Post subject: Reply with quote
Wire wool, WD40 and some elbow grease.
It's quite feasible that you have all the stuff already to make a electrolysis rust removal set up as well.
Norlig
PostPosted: 17:53 - 17 Oct 2013    Post subject: Reply with quote
I did this actually quite recently.
I used a drill with a stainless steel brush end.
Used that all over to get the top coat off.
Then I painted two coats of rust converter. It converts rust to organic metal. It can also painted over.
I then sprayed it with black paint.
https://imageshack.us/a/img189/7866/poud.jpg
https://img14.imageshack.us/img14/7288/hoqn.jpg
https://imageshack.us/a/img27/7184/v9jf.jpg
https://img7.imageshack.us/img7/2478/dk1z.jpg
TomReilly
PostPosted: 18:05 - 17 Oct 2013    Post subject: Reply with quote
Thats a lovely job you did there mate, might pop into halfords and buy a drill piece with the brush head!
Got the majority of it off but still some remains due to it being a large brush, couldnt get into some areas and its too late to remove it.. and im worried i wont be able to get it back on Embarassed
Norlig
PostPosted: 18:16 - 17 Oct 2013    Post subject: Reply with quote
I know its not what you asked for, but somethings are worth doing right, so it doesnt have to be done again Smile
gavcarter
PostPosted: 18:29 - 17 Oct 2013    Post subject: Reply with quote
chemical wise - look for de-oxidising agents, the should absorb the oxygen from the rust slowly turning it back to metal. Depending on how strong the agent will depend on the results but this is all the "rust remover" things are that are available.
TomReilly
PostPosted: 20:25 - 17 Oct 2013    Post subject: Reply with quote
Nice one mate I'll have a look in the morning
tahrey
PostPosted: 09:32 - 18 Oct 2013    Post subject: Reply with quote
"Kurust" was quite good back when I had a car with rotting wheelarches... comes in something resembling an old glue pot, down to the lid having a built-in brush. Bit thin though, you'll make a mess.
Scrape off the worst of it, douse the rest in that stuff, keep it dry for 24h (more if possible), then slather it in anti-rust hammerite.
Wish I'd had (or taken) the time to do that to mine ages ago, it gave way recently and I had to just replace it outright.
The last post was made 13 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 60.16 Kb
