| Dave M |
 Dave M Scooby Slapper
| moonzoomer |
 moonzoomer World Chat Champion
| Dave M |
| gavcarter |
 gavcarter Could Be A Chat Bot
| supZ |
 supZ World Chat Champion
 Posted: 10:10 - 18 Oct 2013 Post subject: |
could be..
# rear wheel out of alignment (not an obvious one but a common cause from inproper chain adjustments)
# headrace bearings shot - feel for clicking when under heavy braking)
# wheel weight fell off - get wheels balanced
# strangely worn tyres - get them checked/replaced
# wheel bearings - could be, but im not sure they'd present wheel wobble.. could be wrong though.
# warped brake discs - could be grabbing the pad pulling the wheel from side to side
lots of things to check  ____________________ CBR954RR - Daily toy
CBR600RR - Trackbike |
| P.addy |
 P.addy Red Rocket
| GeorgeB. |
 GeorgeB. Crazy Courier
| gavcarter |
 Posted: 11:15 - 18 Oct 2013 Post subject: |
| supZ wrote: | could be..
lots of things to check  |
Worn bearings can cause excessive vibration and pulling to one side under braking, i think excessively worn bearings could cause slight wobbling issues, not definate but worth a check. |
| tahrey |
 tahrey World Chat Champion
 Posted: 12:05 - 18 Oct 2013 Post subject: |
Or, if you had iffy steering with low tyre pressure, and it's gone away with the proper pressure, just not worry about it, and commit to checking more often in future.
Especially if you did it very rarely / not at all until now.
Tyres naturally lose air very slightly over time, valves aren't perfect and the composition of atmospheric air lends itself to the stuff escaping. That's why flash johnnies use pure nitrogen fill, apparently it escapes less.
If it's gone down by 5psi over many weeks, that's not so good, but not terrible, may be a very slow puncture. If it's over several months or more, I wouldn't pay it any mind.
If it's sudden or over a matter of days / 1 - 2 weeks, that's more worthy of attention as it's a more substantial leak which could progress to something worse. My old car has a wheel that loses air that fast, and it's because the rim's been badly kerbed and the bead doesn't entirely seal any more. Like, it's probably a tiny fraction of a millimetre out at some point... but it does keep running flat if you don't pay attention.
The handling on my CG goes entirely to shit if one or other of the tyres is low, it's like riding over a bouncy castle, it could well manifest as steering wobble.
However - if it's still there having pumped up the tyre, then ignore all that and concentrate on the rest of the thread
(might you have gone over a big pothole that's slightly warped the wheel, much like on that old car, and caused both a slow leak and made it just out-of-true enough that you can feel it whilst riding, even if it's very difficult to detect otherwise?) |
| Dave M |
 Posted: 10:05 - 19 Oct 2013 Post subject: |
Thanks for all the replies! At the moment I'm going to put it down to tire pressure being low as it has gone away for now! New upgraded tyres will be going on soon before the winter. As for pot holes, roads are that bad nowadays it's near impossible to avoid one! As soon as we get a decent day I will be checking all bearings, tyres etc. Thanks again! |
The last post was made 13 years, 30 days ago. Instead of replying here, would creating a new thread be more useful? |
