Dripping minimoto
askew
PostPosted: 16:01 - 04 Nov 2004    Post subject: Dripping minimoto Reply with quote
Im glad to say that I'm the proud owner of a cheapy half-faired minimoto, which I love to bits. However, the last few times if gone for a mini (acknoledge the pun) ride, the bike has been dripping petrol. It only happens when the petrol is turned fully on, but seems to stop once im picking up speed. I've tryed turning the petrol off, running the engine until it cuts out and then turning it on again. This stops the dripping once the fuel is turned on again for about 2 minutes or so.
Oh yea, forgot to add: The petrol is coming from the small bit of hose under the engine. I assumed that it belonged to the air filter, but now i'm not so sure.
Please help me fix little Jimmy! He needs you Smile
Cheers guys!
What's ya name? What av' ya taken? Chase the lasers, safe as f*ck!
mchaggis
PostPosted: 16:59 - 04 Nov 2004    Post subject: Reply with quote
By the hose under the engine, do you mean the overflow for the carb float bowl? It's possible there's a bit of crap in interfering with the float needle. It can't be a lot or it would be pissing out. A short term fix is often to knock the carb body lightly with a rubber hammer to dislodge it. Eventually, you'll have to take the carb to pieces and clean it out.
I must not be a troll...
Mmmm, Guinness
Guest
PostPosted: 19:52 - 04 Nov 2004    Post subject: Reply with quote
What mchaggis said - it sounds like it's coming from the float bowl overflow, and when you're running the engine is sucking it through quick enough so's it doesn't overfill.
A light tap on the float bowl, and if that doesn't fix it then take the bowl off, clean it out and clean and inspect the float needle. Pay attention to which way up it fits Wink
Hex
Party Boy
PostPosted: 11:29 - 05 Nov 2004    Post subject: Reply with quote
Mines doing something similar at the mo, just haven't been bothered to look at fixing it. Laughing
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
askew
PostPosted: 16:30 - 16 Dec 2004    Post subject: Reply with quote
So, did anyone fix this problem in the end? Little Jimmy is dripping all over the shop now - and I pulled a wheely, fell off and hurt my knee Sad.
Or alternativly, any ideas? I'm really not sure about cleaning the carb... I've never even seen the inside of a carb before. Smile
PostPosted: 17:22 - 16 Dec 2004    Post subject: Reply with quote
What type of minimoto is it, and you'd be best off asking on www.minimotoclub.com/vb/ about it.
And with the wheelie best advice is not to try doing wheelies on them as it is closely followed by falling off the back. Razz
askew
PostPosted: 08:36 - 17 Dec 2004    Post subject: Reply with quote
It's one of those cheapy half faired minimotos like 'dis:
https://www.scottishminimotos.com/photos/bikes/smm1-blue.jpg
I'll head over to minimotoclub, scratch some heads over there.
Hex
Party Boy
PostPosted: 09:26 - 17 Dec 2004    Post subject: Reply with quote
I found that my petrol leak was coming from the actual fuel tap. The joint from the tap to the tank was leaking as as such fuel was dripping out and running down pipes, engine etc etc etc.
The last post was made 21 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 58.08 Kb
