Storing bike over winter
maxp
PostPosted: 18:45 - 21 Oct 2013    Post subject: Storing bike over winter Reply with quote
Hi guys,
Cold / wet / dark nights mean the bike isnt getting used much.
Its not been ridden for two weeks, and my main concerns are gumming up the carbs with the petrol in the float bowl and flattening the battery.
Obviously a bit of a how long is a piece of string question, but how long could it be left before the above (and worse) begin to take affect? Not sure if im overreacting or these are real issues to consider.
bridgedino
PostPosted: 19:17 - 21 Oct 2013    Post subject: Reply with quote
Cold, wet, dark??? Go on...wrap up, get some waterproofs and keep riding
PostPosted: 20:09 - 21 Oct 2013    Post subject: Reply with quote
Plenty of people on here just fill the tank (reduces condensation) and give the battery a charge every month or so and had no problems come springtime.
Pump the tyres up and give the bike a wipe over with some WD40 (not on the discs).
PostPosted: 20:54 - 21 Oct 2013    Post subject: Reply with quote
Shut off the petcock if you have one and drain the float bowls. You can add fuel stabiliser to the tank, although it may be 90% snake oil.
It probably won't do any harm to charge the battery while it's still connected on a carby bike, but you might as well bring it inside and tuck it into a box filled with straw, with a little dish of water in case it gets thirsty.
1cyl
PostPosted: 21:30 - 21 Oct 2013    Post subject: Reply with quote
You could: Disconnect and remove battery. Drain carbs and tank, take weight off wheels and let the tyres down. Buy one of those giant baggies that you can vac out with the Hoover, and a few KG's of silica gel just to be thorough. Zip it all up and store in a controlled environment at about 20 degrees Celsius.
But I find it much easier just to try and use it at least twice a month, even if I'm only doing a 10 mile jaunt, just let it have a long warm up first. It's not like we live in Russia.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Richy CB1000
PostPosted: 21:52 - 21 Oct 2013    Post subject: Reply with quote
Mine lives outside under an Oxford.
Last year left it Oct - Dec cover off fire it up (took 20 seconds) warm up all ok. Back under cover left till end march, start riding!
As the meerkats say simples.......
Dave70
PostPosted: 22:08 - 21 Oct 2013    Post subject: Reply with quote
This. Thumbs Up
The only time I refuse to ride is when the ground's covered in ice. Keeping the bike running is probably the best way to care for it.
-Matt-
PostPosted: 23:10 - 21 Oct 2013    Post subject: Reply with quote
If you have a garage with sockets easiest thing is to whack a trickle charger on it, what i do with mine during winter although [until this winter Evil or Very Mad ] it was used on and off during winter months.
The main problem i noticed with mine, even when not used was the chain - even if its been done relatively recently and you don't remember it getting particularly wet on a ride etc, the air moisture really gets at it once the cold sets in, so give it a good clean and dry down if you're about to leave it sat for a while, and lube 'er up.
It didn't wreck my chain by any means but left rust-specks all over it until i gave it a good brush off, so long term probably not the best i imagine Thumbs Down
pdg
PostPosted: 11:32 - 22 Oct 2013    Post subject: Reply with quote
That's pretty much what I do.
I fill up the tank, then use it, then fill it up again - repeat as required - keeps the fuel nice and fresh.
I charge my battery at least every couple of days by using it.
I have to keep my tyres pumped up otherwise it all gets a bit (more) wibbly in corners.
I'll admit to not much wiping though, sometimes the seat before I sit on it if there's snow or too much water on it.
Rolling Eyes
The last post was made 12 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 62.16 Kb
