| salem1987 |
 salem1987 Scooby Slapper
 Posted: 11:18 - 19 Oct 2013 Post subject: honda h100s tuning |
Hi, just acquired a h100 as part of a deal to play with over winter.
I own other bikes and want to see how much I can actually get out of the little two stroke for a bit of fun!
I've heard the inlet is rather restrictive and have seen this reed on wemoto which could make some improvement to start with... https://www.wemoto.com/bikes/honda/h_100_sg_sj/86-93/picture/reed_valve_-_performance/
Next I have read getting a proper expansion chamber exhaust and bigger carb will help?
And finally does anybody know for sure if the mb8 Athena 125 kit is a direct bolt on?
Thanks for any advice |
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 20:28 - 19 Oct 2013 Post subject: Re: honda h100s tuning |
| salem1987 wrote: | Hi, just acquired a h100 as part of a deal to play with over winter.
125 kit is a bolt on, but you will have to have a custom pipe made for it ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| bladerunner |
| salem1987 |
| _Iain_ |
 _Iain_ Banned
 Posted: 09:23 - 20 Oct 2013 Post subject: |
Gearings fine.
A standard crank/rod shits itself at around 13,500rpm-14,000rpm & you'll be lucky to make it hit 10k on standard porting.
Before improving on stuff i'd sort out what you've already got. Get onto grampian motors, get a piston kit,little end and a few top end gasket sets. Check the plug is an 8 & not a 7 - mine heat siezed on a top speed run as previous owner haddn't done this. Clean the existing expansion chamber out. Mine also ran a smidge lean after servicing as it had a DIY panel filter, upping the main to a 130 sorts this. Put good two stroke in it - currently running comp 2 plus in mine.
While the cylinders off get the files out, you wanna square the top of the exhaust port off - aim of the game is to widen it above the height of the transfers. Also raise the port height by around half a mil. Then out with the files & wet/dry to open the channel out of the head, & smooth it right off. It'll not do much, but it does shift the "pull" from about 5.5-to a 6k takeoff & noticeably goes at 7k.
However it still drops flat after 7 and a bit, so gonna try raising it a bit more when i've got it apart next, but that could be the pipe. I think an MB80 proma pipe will fit, but may want some tweaks & fettling.
If you're really up for a challenge the '82 CR80 motocross motors look to share the same mounting points. If you could get a h100 head on, or make up an adaptor, you'd have 16bhp off the mark to play with. ____________________ Please be aware that the above post may be full of complete nonsense.
| cb1rocket |
 Posted: 09:41 - 20 Oct 2013 Post subject: |
| _Iain_ wrote: | Gearings fine.
If you're really up for a challenge the '82 CR80 motocross motors look to share the same mounting points. If you could get a h100 head on, or make up an adaptor, you'd have 16bhp off the mark to play with. |
The pipe is weakest point, the standard pipe is designed for mid range, so whatever you do it will always run flat after 7k rpm. 17th front sprocket is a must ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| cb1rocket |
| salem1987 |
| salem1987 |
| cb1rocket |
 Posted: 20:47 - 21 Oct 2013 Post subject: |
I would just buy the 150 quid kit, you can get the pistons on their own, also I think the stock barrel bored out to 125cc will mean no liner left! ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
| moonzoomer |
 moonzoomer World Chat Champion
| bladerunner |
| moonzoomer |
| bladerunner |
 Posted: 23:28 - 21 Oct 2013 Post subject: |
That's not bad tbh! Shorter gearing to 70-75 helps ....but would expect 80+ with a tuned road bike motor......if that's really where you'd want to be on a H100  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
| moonzoomer |
 Posted: 00:06 - 22 Oct 2013 Post subject: |
| salem1987 |
| cb1rocket |
| salem1987 |
 Posted: 11:51 - 22 Oct 2013 Post subject: |
thanks yeah i am aware of that. I've had a go at the rear wheel anyway and (not suprisingly) it is not a direct swap. The CD200 sprocket carrier is about 1cm offset compared to the h100.
The front however looks more possible, the yoke stem and headstock seem to match after some quick measurements.
Another reason for this possible conversion is that i have clip on bars for the cd200 forks and a spare cafe racer hump seat.....
Had the carb apart again today and noticed the needle was on the top notch. With no airfilter foam in the box and the needle this low im surprised its not running dreadfully lean. |
| _Iain_ |
 _Iain_ Banned
| salem1987 |
| _Iain_ |
 _Iain_ Banned
 Posted: 15:59 - 22 Oct 2013 Post subject: |
Chef!
Where'd the clip ons come from & how on earth do you ride with them? ____________________ Please be aware that the above post may be full of complete nonsense.
| salem1987 |
| salem1987 |
| salem1987 |
The last post was made 12 years, 240 days ago. Instead of replying here, would creating a new thread be more useful? |
