RS125 Help - Won't Run After Carb Clean/No Fuel to Barrel
sinedtomuch This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 15:20 - 25 Oct 2013    Post subject: Reply with quote
Buy a BR10 from ebay.
Remove the carb again, also remove the fuel hose and check for it being perished, any filters?
PostPosted: 15:35 - 25 Oct 2013    Post subject: Reply with quote
Don't user that air filter, just grab a stock one and make sure you are using the stock airbox.
PostPosted: 16:03 - 25 Oct 2013    Post subject: Reply with quote
Can you ride through it with a steadily opening throttle or are you trying full throttle?
PostPosted: 17:05 - 25 Oct 2013    Post subject: Reply with quote
Suggests it is rich, probably fuel wise. But if you have been doing lots of short runs then it might well foul up a plug rapidly. A 10 will likely foul up more quickly than a 9, and I wouldn't expect a 9 to give the problems you were having (rather issues when thrashed with the plug over heating).
nathan k
PostPosted: 17:35 - 25 Oct 2013    Post subject: Reply with quote
What colour is the spark? (hold the end against the cylinder, don't shock yourself, and crank the engine)
Is it a air box you're using? Race filters need up jetting by roughly 10 sizes.
nathan k
PostPosted: 18:33 - 25 Oct 2013    Post subject: Reply with quote
sinedtomuch wrote:
Well i've replaced it with a new plug. I'm not sure what size of jets are in the carb atm as I only bought the bike a month ago and don't know if the guy upjetted or not. Is there a way to check what jets are in it the carb atm?
Take the float bowl off and might as well check jets are clean still while your at it.
A weak spark might be to do with cdi etc, check the colour mate, it's meant be a bright blue.
PostPosted: 20:56 - 28 Oct 2013    Post subject: Reply with quote
Compression sounds fine.
One thing to check, when cranking over normally (with the plug in place) is it sparking? Use an inductive strobe light to check. If not then check the distance between the flywheel and the pickup. If that is too large then it won't trigger a spark properly.
bypass2
PostPosted: 23:21 - 28 Oct 2013    Post subject: Reply with quote
when you took the carb of was there any or much petrol in the bowl. what are the float heights set at.try the myddle notch on the throttle slide clip.
bypass2
PostPosted: 19:30 - 29 Oct 2013    Post subject: Reply with quote
is the plug still sparking. have you tried bump starting it. you said its the full power rs so thats the one with the exhaust port rave valve would this stop it running if it was full of carbon or stop the petrol going to the barrel
Robby
Dirty Old Man
PostPosted: 19:45 - 29 Oct 2013    Post subject: Reply with quote
What have you done to the bike. Trying to diagnose problems like this is a difficult process if you've fitted silly jets or removed the reed block thinking it was restrictor.
If it won't start normally and the choke just kills it, and your carb is clean, I would be looking at what you have changed on the carb and setting it back to where it should be.
The last post was made 12 years, 293 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 123.52 Kb
