Fuel Float conversion?
binge
Emo Kiddy
PostPosted: 10:09 - 17 Dec 2004    Post subject: Fuel Float conversion? Reply with quote
Right. A while ago I changed my standard speedfight bars for a set of Renthal Style street bars. This resulted in Removing the whole dash and Just having a Bycicle Digital speedo...
Its the second time Ive had to push to a petrol Garage now Wink ...
I was in the garage messing around with my scooter, I took the float out and saw that I could probably bodge a couple of terminals onto 1, The swing arm of the float, and 2, The bracket in which the float pivots on...
I then wired these up to a bulb and a battery and used the float as a switch. When I lifted the float up, the bulb went out, when I let the float drop and the bub lit....
I was just about to put my float back in the fuel tank and It clicked...
When the terminal make contact they cause a small electrical spark dont they...
Resulting in a big explosion wit it being in the fuel tank...
Is there a safer way to do a similar sort of mechanism...
Cheers <|Binge|>
Oh, heres a diagram of what I created...
binge
Emo Kiddy
PostPosted: 15:38 - 17 Dec 2004    Post subject: Reply with quote
Can anybody tell me if the above method is safe Wink
Cheers...
<|Binge|>
Lone-Wolf
PostPosted: 16:00 - 17 Dec 2004    Post subject: Reply with quote
Wotcha.
Just make sure you are well insured against fire. There again, that will be the least of your worries because the the tank will explode first.
I take it there used to be some kind of fuel gauge, or does the float in the tank serve some other purpose ?
Cheers.
L.W. - www.moonshiners.org.uk
stryker
PostPosted: 16:33 - 17 Dec 2004    Post subject: Reply with quote
Firstly, so long as the tank is sealed you'd not have a explosion, in fact with a breather you'd probably not have an explosion. Its pretty hard to even light a casserole dish with petrol in the bottom as above the petrol there would be no air (called vapour lock with zippos).
To be safe though, you need to run as little voltage/current through the contacts as possible. IE run just a couple of volts through the contacts, use this to drive a power transistor, and use the output of that to drive a relay which controls the power to your bulb. In honesty you can do away with the tranny and just use a low power relay.
Thats about as simple as I could put it.
Now what?
mr.z
PostPosted: 16:55 - 17 Dec 2004    Post subject: Reply with quote
By the way fuel indicators tend to be horribly inaccurate anyways i'd personaly just use the trip/odometer (well i do anyways)
That way you don't risk becomeing a two wheeled ball of flame (and it does happen)
The trip is less of a pain than you would think, as long as you remember to reset at every refill its foolproof... the tricky bit is seeing how much fuel you get till you run out, set your trip, get a 5L can of petrol to take with you, ride till it runs out... thats how many miles you get! Wink
Bit lowtech but i haven't been left petrol-less for two years.
Lone-Wolf
PostPosted: 17:03 - 17 Dec 2004    Post subject: Reply with quote
Wotcha.
Correct, to some extent.
Petrol itself will not burn - you could ( if you're brave / daft to try ) extinguish a lit match in a FULL petrol tank. It's the petrol vapour that burns, and when mixed with air at roughly 14:1 ratio it burns rather well. So well in fact that it will explode and push your piston down.
When you get that nasty situation where the petrol level drops, and the contacts make, you can bet that sooner or later there would be enough air in the tank for something 'interesting' to take place.
Personally, I wouldn't entertain the idea of a switched contact fuel warning light - but that's me Smile
Cheers.
binge
Emo Kiddy
PostPosted: 19:31 - 17 Dec 2004    Post subject: Reply with quote
Well there is a Varieable Resistor in the tank anyway. Surely that would create small sparks...
Any way, Im only insured TPO so im not going to risk it....
I dont have a trip omenter...
Ive got a 100ml bottle of brake fluid (Nearly empty) And ive got to bleed my rear so ill use up the rest of the bottle. Fill it with petrol and stick it down in my battery box inside the belly pannel. That way ive got a fair bit of spair fuel if I do run dry...
How often should I use the petrol in this bottle and put fresh in?
<|Binge|>
divuk83
PostPosted: 20:06 - 17 Dec 2004    Post subject: Reply with quote
I do the same thing with my petrol mate. No guage on mine, just stops when its out. although I dont use it everyday and its garaged at the mo. I just put a 5 litre petrol can in my bag when I go out and insure its filled up. To make things more fun I also run on pre-mix so I carry little measuring bottles of oil about with me too Very Happy Usually try and run it down as low as possible for sprinting to cut down on weight, so its always near empty Very Happy
Scooter center sell cool little oil bottles that I use. They have guages for each percentage of premix on the side.
https://www.scootercenter.com/catalog/product_info.php?manufacturers_id=44&products_id=782
Get a 5 litre fuel can from halfords, I reckon it would fit under your seat for emergencys as its quite roomy under a speedfight seat.
Didn't your speedfight have a fuel guage before? If so take it out of the old instrument panel and drill a hole through the legshields and mount it there using the old wiring.
Dave
binge
Emo Kiddy
PostPosted: 20:16 - 17 Dec 2004    Post subject: Reply with quote
Thats a good Idea. BUT the speedfight clocks are SHIT! they are like a single plastic mould...
<|Binge|>
(A 5ltr cans a bit big) 100ml will do Wink
I dont bother with Pre mix either... Scoots fast enuf thanks. Razz It will keep up the boot of most 125 scooters Very Happy
Lone-Wolf
PostPosted: 20:53 - 17 Dec 2004    Post subject: Reply with quote
Wotcha.
I always wondered about using a variable in the tank, but when I took a good look at one I realized there is always 'some' contact, so you never get the 'make and break' which is what causes the spark.
If your tank already has the sender unit, why not fit an aftermarket fuel gauge ? That's what I've done on both trikes. Doesn't cost a lot, and is a damn sight better than trying to push the things.
Cheers.
binge
Emo Kiddy
PostPosted: 10:37 - 18 Dec 2004    Post subject: Reply with quote
I was going to do that but...
The wires at the front all go into a couple of box clip connectors wirh like 30 wires in each (Was for the top cowl clocks and lights before I removed it)...
Now ive found the dashboard clock lights because ive used that to add a smal LED to enlight my Digital speedo at night,,,
How do I go about finding the fuel gague Live and earth?
And how would I wire them up to an aftermarket gague...
Also, any Ideas on a temp gague...
My scoot already has a thermomiter in the cylinder and A wire (Just 1 Confused ) leading up to the box connector too...
<|Binge|>
mchaggis
PostPosted: 06:55 - 19 Dec 2004    Post subject: Reply with quote
Naked electrics + fuel vapour = boom.
Not that difficult to understand, surely? Very Happy Doesn't this bicycle speedometer have an odometer function too? Surely you can use the age old methods of a) checking your tank to make sure you've enough before you leave, and b) keeping tabs on your accrued mileage since the last fill up?
I must not be a troll...
Mmmm, Guinness
binge
Emo Kiddy
PostPosted: 10:55 - 19 Dec 2004    Post subject: Reply with quote
Well theres actually a Variable resistor in the fuel tank atm. It was a part of the origional fuel gague. But since I changed my handle bars there is no room for the fuel gague so I came up with the idea of bodging the switch mechanism onto the float and puting am LED up at the bars...
BUT letrally 10 seconds before I droped that float into the tank I realised that when the terminals make contact, Im dead!
<|Binge|>
(Its like a bomb from 1 of them stupid movies like "Speed")
U kno.... Let your tank drop below 1/4 and your bike will explode! Wink
The last post was made 21 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 82.54 Kb
