No Red Master Key
BikerGirlonGi...
PostPosted: 13:45 - 28 Oct 2013    Post subject: No Red Master Key Reply with quote
Been lusting after a black Kawasaki 636 2005/6 model. Found one for £3400 with alleged 8000miles on the clock with a few mods. I was all set to buy until I found out the dealer has only 1 key - and it's not the master key!
Would I be correct to avoid buying this, as isn't the master key important for key cutting, data mapping etc? To replace would cost around £1000 as would need new ecu too?
Please advise! Sad
SQL
PostPosted: 13:51 - 28 Oct 2013    Post subject: Reply with quote
avoid
PostPosted: 13:51 - 28 Oct 2013    Post subject: Re: No Red Master Key Reply with quote
You should be able to get a key made up for considerably less than that I'd have thought.
Maybe not a 'master key', but should be able to get another transponder key made up if you have the existing key.
Haven't looked in to bike keys specifically, but there's places that do the same for car keys and as far as I'm aware the transponders work the same.
SQL
PostPosted: 13:57 - 28 Oct 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/kawasaki-zx6r-636-ninja-b1h-/251366919300?pt=UK_Motorcycles&hash=item3a86a2cc84
BikerGirlonGi...
PostPosted: 14:17 - 28 Oct 2013    Post subject: Reply with quote
SQL - Why do you say avoid? Thanks for the link, it looks like a clean and lovely bike, but I'm not a fan of their design, I much prefer the 2005/2006 model.
G - Doesn't the red key access the ecu's date (mileage, mapping, clock etc...)? Wouldn't the value of the bike without this key be much negated? Or would you still proceed with the purchase?
PostPosted: 14:18 - 28 Oct 2013    Post subject: Reply with quote
Having 1 black key would not bother me in the slightest.
PostPosted: 14:24 - 28 Oct 2013    Post subject: Reply with quote
I don't know for that specific model - in cases I've seen the master key doesn't do anything special bar let you code new keys. But other cases may well be different.
I would certainly use it as a bargaining tool - or request they get one sorted.
It's far from uncommon to find key's lost as you're getting towards 10 years old.
SQL
PostPosted: 14:48 - 28 Oct 2013    Post subject: Reply with quote
I say avoid because you know if you lose the key it will cost you 1k
andys675
PostPosted: 15:12 - 28 Oct 2013    Post subject: Reply with quote
get the black one cloned
I'm not sure what the red one does exactly, but it is needed to put new key codes in the system, if you have the one you've got cloned it has the same code and doesn't need the red one to install a new code
PostPosted: 16:04 - 28 Oct 2013    Post subject: Reply with quote
#1 Be aware that if the bike is stolen, your insurer might ask for two keys as a condition of paying out.
#2 Check that it's not stolen / recovered. Wouldn't bother me, but it might bother anyone you want to sell it on to.
#3 Tell the seller that it's a big deal to get a spare. If they claim that it's not, then invite them to produce one if they want your money.
Fizzer Thou
PostPosted: 16:16 - 28 Oct 2013    Post subject: Reply with quote
Phone or email Kawasaki UK and ask them about the red key
https://www.kawasaki.co.uk/Info/Details/340D76D3662
Always have a 'Plan B'
BikerGirlonGi...
PostPosted: 17:30 - 28 Oct 2013    Post subject: Reply with quote
Thank you for the helpful feedback.
I got the dealer to buy a spare from Kawasaki and thrown it in the deal, with a £300 reduced asking price. Paid deposit.
Happy riding soon!
(Damn I've missed riding) Very Happy
PostPosted: 20:53 - 28 Oct 2013    Post subject: Reply with quote
Spare key or a replacement key?
A cloned replacement is easy enough, but not sure what else the red key is used for other than programming new keys.
PostPosted: 21:03 - 28 Oct 2013    Post subject: Reply with quote
Either way, good job by all concerned and happy days ahead. Thumbs Up Don't snow don't snow dont...
evoboy
PostPosted: 21:16 - 28 Oct 2013    Post subject: Reply with quote
For Honda's HISS system, you dont need a 'master' key, just a coded key to get into the reprogramming system.
Somthing like, remove the plug for the crank position sensor and bridge the wires to the loom. It puts it into key coding mode. ( cant remember 100% )
APT Motorcycles
Ammoman
PostPosted: 21:27 - 28 Oct 2013    Post subject: Reply with quote
Why worry about it? Just get another cut even if it needs programming. Got one cut and programmed for my Busa for £45. Thumbs Up
2013 ZZR1400 & Honda CG125 1986..
PostPosted: 21:37 - 28 Oct 2013    Post subject: Reply with quote
Ammoman wrote:
Why worry about it?
The worry is that on some of these systems the red key may be required for other things. And a £1k bill for a new ECU and red key to be able to do these things can be a touch nasty.
But not a clue with the Kawasaki system what it is required for, or if just for programming a new key (in which case a clone is the cheap and easy solution).
By the way, some markets didn't have this key system on their models, so if an import check if it should have a red key.
Slacker24seve...
PostPosted: 08:59 - 29 Oct 2013    Post subject: Reply with quote
Surely a dealer has the facilities to clone a master key?
Banger rallies are ace
Skudd
PostPosted: 10:51 - 29 Oct 2013    Post subject: Reply with quote
I was going to say with my Honda from new I only got two black keys for the HISS system. I just swap them every now and then to make sure that they both work.
PostPosted: 20:51 - 29 Oct 2013    Post subject: Reply with quote
If you have the master key then no problem.
The master key normally allows other keys to be programmed to work. With no master key you cannot program the bike to accept other keys, hence all you can really do is clone an existing key that works (and if the bike decides to no longer recognise that keys code you are stuffed).
My understanding is that on some of these systems there is nothing special about the master key, merely that it is the first key to be used with the ecu.
There are people around who say they can make up a new master key. In which case they would need to reprogram the ecu to accept a new master key. Possibly all they need to do is wipe the record of the master key from the ECU.
j.silvs
PostPosted: 21:00 - 29 Oct 2013    Post subject: Reply with quote
I am able to get so called master keys cut for £50. Even from the spares
Dagenham market mate
The last post was made 12 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 111.77 Kb
