I've got an issue.
Beehive Bedlam This post is not being displayed because it has a low rating (Redundant). Unhide this post / all posts.
lihp
PostPosted: 21:32 - 28 Oct 2013    Post subject: Reply with quote
You have to weld front sprockets on?
Andy_Pagin
PostPosted: 21:35 - 28 Oct 2013    Post subject: Reply with quote
They welded a sprocket to a shaft? How the hell did they align it anywhere near to acceptable mechanical tolerances?
Wobbling Dog
PostPosted: 21:40 - 28 Oct 2013    Post subject: Reply with quote
wakefield to silsden on a 125 every day ! jees
PostPosted: 21:55 - 28 Oct 2013    Post subject: Reply with quote
Sprockets and output shafts are usually made form high-carbon steel so it can be heat-treated and drawn to a suitable hardness so the bits don't wear out. Welding either will upset this heat treatment and might well lead to a failiure of the weld, or even the shaft. I have seen probably a handful of welded-on sprockets on various machines and most have either a cracked weld or evidence of re-welding (obviously following a craked weld). It's very likely that they could be welded but using a specific procedure and using pre- or post-weld treatment - I don't know, I'm not a welder - but in my opinion the odds are on that it will crack at the weld sooner or later.
If the 'damage' was just a retaining clip groove or something it would be far better to put the sprocket loose onto the shaft and then put a blob of weld on the shaft to stop it slipping off. If the shaft spline is shot so that the sprocket can spin on the shaft, then welding is about your only option unless you want to strip or replace the engine.
SQL
PostPosted: 22:21 - 28 Oct 2013    Post subject: Re: I've got an issue. Reply with quote
CumDumpster99 wrote:
In September the 13th my Varadero, failed me and left me stranded at 05.30 in Wakefield on the way to work.
The sprocket shaft what front sprocket connects to failed I wheeled it to a nearby garage and he told me the bad news and gave me two options.
1) Buy new Engine from ebay.
2) He would weld it on but no guarantees so I won't be able to take him to court in case it fails. (his mate who doesn't work there did it using the garages tools).
I went with the latter so off I went to get a new front sprocket to be welded on for the cost of £30.
It has been fine so far covering 38 miles to Silsden and back every day in torrential rain and flooded roads even cars wouldn't drive through.
Within the last three weeks I noticed when I hold the clutch in and roll I can feel a very light click is this due to the weld? I have cleaned and lubed the chain often there has been no oil leaks. The chain is at the correct tension.
I've put on nearly six thousand miles since I purchased it and added no damage and have complete ten year history so could easily get back £1200 I paid.
Should I sell and get another or will it be able to be grind off as the mechanic suggested?
Jivebunny?
Nobby the Bastard
Harley Gaydar
PostPosted: 22:29 - 28 Oct 2013    Post subject: Reply with quote
If you sell it, are you going to tell the potential buyers about this fine example of mechanical ineptitude?
Triumph Sprint ST 1050
SQL
Ill give you 5 ponds.
kestrel
PostPosted: 22:31 - 28 Oct 2013    Post subject: Re: I've got an issue. Reply with quote
SQL wrote:
Jivebunny?
Thread is definitely in the JB style...............
Isle of Man.........Road Racing Capital Of The World
LockyUK
PostPosted: 00:12 - 29 Oct 2013    Post subject: Reply with quote
sql, you are bang on... jivebunny... what a cock, shame he did not crash and burn tho.
Alice-In-Sunderland This post is not being displayed because the poster is banned. Unhide this post / all posts.
woo
PostPosted: 00:50 - 29 Oct 2013    Post subject: Reply with quote
so when you need to take off the front sprocket due to needing a new one how is that done?
Elen sila lummen omentielvo!
SQL
PostPosted: 00:53 - 29 Oct 2013    Post subject: Reply with quote
He won't need to as the bike will be fucked by then.
Rigga
PostPosted: 02:07 - 29 Oct 2013    Post subject: Reply with quote
Just weld some new teeth on it Laughing
Current bike: Honda CBR 1100xx
johnsmith222
PostPosted: 02:38 - 29 Oct 2013    Post subject: Reply with quote
A) Do I sell it on now while it's still munching up the miles.
If you don't mention this issue to prospective buyers then I hope that someone like hetzer buys it. Thumbs Up
woo
PostPosted: 02:40 - 29 Oct 2013    Post subject: Reply with quote
give these guys a ring see if they can help they have helped me big time
https://www.mhmotorcycles.co.uk
Nick 50
PostPosted: 05:45 - 29 Oct 2013    Post subject: Reply with quote
This .......................
and
Whenever anything is welded, things distort, no matter how good the weld/welder.
He has welded a shaft, which has now distorted is some manner. This will very likely now create a moment on the shaft which will kill the bearings on the shaft pretty quickly.
Good luck selling it in that state. The buyer probably wont see the bodge at first, but they will at some point. Depending on how long you've had the bike, it will be a fair bet they could take you to court and get the money back you scammed out of them.
Fisty
PostPosted: 05:46 - 29 Oct 2013    Post subject: Reply with quote
https://4.bp.blogspot.com/-8z7eWRqEpFI/T8k-ZmIqO1I/AAAAAAAAAFU/oxqXucy5sBk/s300/window%2Blicker.jpg
Fatter and faster than Fret
Fisty
PostPosted: 05:53 - 29 Oct 2013    Post subject: Re: I've got an issue. Reply with quote
I've got an issue.
No, you have many, many issues your bike is only one of them. Your main one is your inability to listen to advice and just plough on headfirst not knowing what the fuck you are doing.
The result is things get fucked up (such as the above) and you then get abusive with us.
I for one am done helping you, we tried repeatedly to help and all we got was abuse.
Carry on screwing things up. One day it will bite you in the ass.
PostPosted: 09:49 - 29 Oct 2013    Post subject: Reply with quote
You can start a new account, Jive, but karma still catches up with you. Wrecking your Daewoo was bad enough, but someone could have had use out of that Varadero.
Sell it, ride your R6.
Wonko The Sane
PostPosted: 22:28 - 29 Oct 2013    Post subject: Reply with quote
B) Keep it and hope it can be bodge jobbed when it needs replacing.
How about start saving towards getting the bodge (which is essentially a temporary repair) sorted properly so that you can keep using the bike for a few more years?
The last post was made 12 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 126.01 Kb
