disconnected front brake light wire
Lardedah
PostPosted: 17:51 - 29 Oct 2013    Post subject: disconnected front brake light wire Reply with quote
This is the 3rd time I've made a thread on here I know that little..
My back light was until 5 minutes ago permanently light up, just checked my rear brake sensor, all is fine. After a quick scan in my haynes, I unplugged the front sensor wire from the 'box' and my light issues seem to be no more, but that wire is just loose at the moment, I've ran the bike idle for 5 minutes, am I okay to use the bike as normal from now on? Just need someone to help me wrap up yhis 'loose-end' pun 100% intended.
Don't know a thing.
map
Mr Calendar
PostPosted: 18:04 - 29 Oct 2013    Post subject: Reply with quote
Confused Some clarification needed.
So when you pull front brake lever the brake light at the rear still lights ok?
Lardedah
PostPosted: 18:14 - 29 Oct 2013    Post subject: Reply with quote
Sorry, no the front brake doesn't illuminate the light at all(MOT failure?), only the back brake will illuminate it. Thought that this would do for now, since I have always applied the back brake first and then bring in the front
Don't know a thing.
PostPosted: 18:37 - 29 Oct 2013    Post subject: Reply with quote
Definite failure.
Try joining the 2 wires at the front, if the light illuminates, it is likely the switch is duff.
BrownTrousers
PostPosted: 18:46 - 29 Oct 2013    Post subject: Reply with quote
I don't know if you actually are (or should be) always using the back brake first or whether or not it's an MOT failure (I assume it is), but I know that a situation where pulling your front brake doesn't illuminate your brake light doesn't mean your 'issues are no more'.
Get it fixed before someone runs into the back of you.
/boring safety stuff
Bikers make great organ donors - add your name to the register
Ducati Multistrada 950 | Triumph Tiger 800 XR | Honda CBR500R | Yamaha YBR 125 Custom
Robby
Dirty Old Man
PostPosted: 19:49 - 29 Oct 2013    Post subject: Reply with quote
What bike?
The front brake usually has a micro-switch next to the lever, moving the lever operates the switch. Sometimes they can jam on or off, the fix is either replacing the switch (cheap) or taking it apart and fixing it (what I do).
If you're going to take it apart, do it inside at a table. They tend to contain very small springs and contacts that like to go ping when you lever the switch open.
In its current state your bike is an MOT fail and dangerous as well.
totalllama82
PostPosted: 21:06 - 29 Oct 2013    Post subject: Reply with quote
Sounds like you need a new switch. eBay or wemoto are your best bets. As said they can be taken to bits and cleaned up but are a real pain in the arse - especially if you open it to find a puddle of rusty metal in there.
Goes without saying using the bike without a working brake light will end badly.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
PostPosted: 21:30 - 29 Oct 2013    Post subject: Reply with quote
Depends on the age of the bike whether it is an MOT fail, but for most bikes it will be a fail.
Likely it is the switch. On some bikes there is a small ball bearing between the lever and the switch which can stick (or be lost when the lever is taken off).
Lardedah
PostPosted: 21:42 - 29 Oct 2013    Post subject: Reply with quote
Thanks guys, will have a look for switch but don't remember seeing anything. For the fiddly job of taking it apart, might take it to small garage near work that seem to be really good.. Richardsons ? In Congleton. As for riding with a dodgy brake light set up it is of course a bad idea safety wise especially in this crap weather, was more concerned about the circuit not being complete/exposed to rain.
edit: is a 2009 keeway speed 125, first bike picked it up cheap this will be the millionth thing I've had to fix.
Don't know a thing.
el_oso
PostPosted: 23:17 - 29 Oct 2013    Post subject: Reply with quote
I'm not sure if I'm reading this right, but here goes.
Your brake light should have two filaments in. One slightly dim one which is your normal back light. You should also have a much brighter light when you press the brake. Now before you disconnected that wire from the front how bright was the light? Was it full brightness or standard running lights? What happened if you pressed the back brake? Did it light up or change or do anything?
When you pull the front brake lever can you hear a click at all?
My understanding is that if all the wires are connected up the rear brake light is permanently on? If this is the case I would suspect the rear brake switch is adjusted badly. Try disconnecting the rear brake switch from the connector block and see what happens with the light. If it is how you say still permanently on i.e. brake light then it is probably the front brake switch.
Duke 390
Car: Jeep Wrangler 4.0L
bladerunner
PostPosted: 01:16 - 30 Oct 2013    Post subject: Reply with quote
Does sound like the switch is sticking. You do have a working brake light so long as you use the rear....which means its not a safety issue but as you say will be an mot fail UNTILL you change or fix the switch...they only cost a few quid.
Lardedah
PostPosted: 11:28 - 30 Oct 2013    Post subject: Reply with quote
It was defiantly the bright brake light that was illuminating, and whilst that was on (that was ALL of the time) none of the controls ( that's either brake and the normal light switch) would make the slightest difference to the brightness.
I unhooked the rear brake switch mechanism and the light was still on full + then I put that back together and unplugged the front switch wire and light completely went out. If I then put my lights on then the correct bulb would light up, and If I put my back brake on, the brighter bulb would light up. Defiantly front switch.. Didn't hear a click when I unplugged the front brake switch.
Divvy, did leaving that wire exposed cause you any grief? If not I guess am happy to run it as normal until new switch comes.
Don't know a thing.
PostPosted: 13:02 - 30 Oct 2013    Post subject: Reply with quote
Vincent wrote:
I always disconnect my rear brake light switch. The idea being that, if I don't want certain people to know that I'm slowing down, I can use the back brake only.
Like who Confused That is basically asking to be rear ended.
Lardedah
PostPosted: 15:24 - 30 Oct 2013    Post subject: Reply with quote
So they didn't actually fail you for the brake light issue?
Don't know a thing.
The last post was made 12 years, 294 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 102.03 Kb
