| nathan k |
 nathan k Spanner Monkey
| gixerladsw |
 gixerladsw Nitrous Nuisance
 Posted: 12:11 - 29 Oct 2013 Post subject: |
Just practice your left turns. You might find you are now subconsiously (however you spell that) stiffening up when turning left as you think it is a problem, you are now making it a problem.
Would advise keep practicing , make an effort to relax, if you have a mate you trust get him / her to ride a bit faster than you might normally go round a left hander and follow them. You might find that helps as you are concentrating more on following them. Just a thought.
If it is getting really bad, maybe, you have a balance issue etc. see your doc to make sure you don't have a balance, eye sight issue or owt. Always a possibility.
Or of course, option 3, the standard biker / bikechat forum answer.
Man the FUCK UP and get on with it. stop being a pussy!  |
| MarJay |
 MarJay But it's British!
 Posted: 12:14 - 29 Oct 2013 Post subject: |
It's probably just psychological thing. Remember all roundabouts are right handers, so you've had more practice at smooth right handers than left handers. Also, because we ride on the left hand side of the road, left handers tend to be tighter than right handers.
However, I have had a similar but more subtle issue in the past, and I found that my rear wheel alignment was off by a long way. Despite using the alignment marks on the swinging arm to align the wheel, I was off by a few degrees. I used the string method to align the wheel and sorted the problem.
Check the bike first, make sure the wheel bearings are OK, the head bearings are good and the wheel alignment is OK, then if it is not a technological thing I'd start to address the psychological issues. If you're going to do a race school I can recommend the California Superbike School, it's more of a school than Ron Haslam which to me sounds a bit like an 'experience day' type affair.
Alternatively do a trackday and ask for some tuition. Track day organisers usually have instructors available, although they aren't often as good as full time instructors they might be able to give you some pointers. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| P.addy |
 P.addy Red Rocket
I hate right hand bends.
I love left hand bends. I have the same feeling in a car.  |
| Hetzer |
 Hetzer Super Spammer
| esullivan |
 esullivan Could Be A Chat Bot
| nathan k |
| MarJay |
| esullivan |
 Posted: 12:39 - 29 Oct 2013 Post subject: |
| MarJay wrote: | | esullivan wrote: |
I've found easier to do "counter leaning" sometimes. Stiffen the left arm a bit while applying pressure on the left bar. Your upper body will stay more upright while the bike leans, sort of like pivoting at the hips. This is normally for "flicking" the bike, such as in the mod 1 avoidance exercise, but I find I'm more comfortable at higher lean angles/pace this way than the more traditional hang-off-the-bike lean (left elbow pointing to the ground, head near left mirror). |
That is bad... You shouldn't lean against the angle of the bike. It puts more pressure on the tyre and makes the bike lean more for a given turn. You should at very least lean with the bike, but most modern bikes are designed for you to hang off a bit. |
This is true at high speed -- should have mentioned that. Don't counter lean at the track.
At lower/sensible speeds, though, flicking the bike back and forth this way makes for tighter turns with less lean. Try it, if you don't believe me. You likely had to do this on the avoidance part of the module 1, whether you were aware of it or not. You didn't hang off the bike. You stayed mostly upright and flicked the bike beneath you. ____________________ Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125. |
| jjdugen |
 jjdugen World Chat Champion
| Cadbury |
 Cadbury Crazy Courier
 Posted: 12:57 - 29 Oct 2013 Post subject: |
Strangely, I'm slightly the opposite.
In my day to day riding (to and from work) I do way more lefts than right, specifically the slip roads on and off the various motorways i use are all fast left handers, and I only encounter one (mini) roundabout that requires a right turn, as a result I'm much more comfortable on a fast left hander than rights  |
| Bubblin77 |
 Bubblin77 Nitrous Nuisance
 Posted: 13:36 - 29 Oct 2013 Post subject: |
| jjdugen wrote: | Right hand side chicken strips are always 'less' than L/H side because of the cambers in the road surface. The surface comes to you on rights, falls away on left hand bends. I tend to treat left hand bends with a bit more caution than rights, you can see through a right hander, lefts tend to be blind (er).
Funny about the counter-steer comment, I tend to counter on lefts (to keep my head from smashing the roadside furniture) and hang off on rights. This on tight fast backroads, normal riding on A roads I just let the bike do its own thing, you are rarely anywhere near its true capabilities. |
I think this is an urban myth, after investigation it's due to the speeds we take the majority of turns, left hand turns are sharper and bend radius are tighter than right turns, in the uk at least. Hence the difference in wear.
For me, love left hand turns hate right hand turns, in my head if I fell off I would like to fall off on my left side.
Strange I know. ____________________ Kawasaki Z800 (SOLD) |
| Daytona Paul |
 Daytona Paul Scooby Slapper
 Posted: 13:51 - 29 Oct 2013 Post subject: |
Left bends should feel better as the camber normally helps us, at least as long as we keep left of the centre line
Should you accidently cross the centre line on a left hander the camber will normally push you wide very quickly this is where a little counter steer could literally save your life!
Keeping the bike in a low, responsive gear (about halfway through your bikes rev range) will also help. ____________________ www.angliaroadtraining.com
CBT FROM ONLY £85
Back to Biking Refresher Day £99! Book with a friend and get 20% Discount! |
| The other Paul Rudd |
 The other Paul Rudd Scooby Slapper
| trevor saxe-coburg-gotha |
 trevor saxe-coburg-gotha World Chat Champion
| C1REX |
 C1REX Traffic Copper
 Posted: 14:47 - 29 Oct 2013 Post subject: |
There can be lots of reasons why you have problem with left hand bends.
1. Lack of practice.
2. Wrong riding position.
3. Wrong speed and gear.
4. Bad observation.
Big number of serious motorcycle accidents happen on non built-up left hand bends.
Overconfidence can be much worse than lack of it. ____________________ MCForum meetup - One of the biggest motorcycle clubs in UK |
| bikertomm |
 bikertomm World Chat Champion
| iooi |
 iooi Super Spammer
| esullivan |
 Posted: 17:14 - 29 Oct 2013 Post subject: |
| iooi wrote: | | esullivan wrote: | in Britain we take many more right-handers than lefts (think roundabouts) |
Do we?
Roundabout?
You tend to turn left onto it, go round right and then turn left off it. So your average straight on = pretty much the same amount of time on each side. |
OK, I meant at speed, but still. Good point. I count more lefts on my route to work too, but I'm going a lot faster on the rights.
We now have multiple theories for the differences in wear on the left and right side of the tyres in this thread -- camber, speed, number.
I don't think I plucked this idea out of the ether. Something must be causing this. Walk down a bank of parked motorcycles sometime. If the strip is wider on one side, it's usually the left in Britain, while if you go to France or the U.S., it's the opposite. So, why is that? I'm inclined to believe it's a combination of speed and camber.
(Edit: Not everyone has different width strips, so edited to make the point clearer.) ____________________ Current: '14 VFR800X Test passed 31/10/12.
| Doovy |
 Doovy World Chat Champion
 Posted: 17:35 - 29 Oct 2013 Post subject: |
When navigating left handed bends, if you low-side you will slide into oncoming traffic.
When navigating right handed bends, chances are you will go into the curb/bushes/trees/ditch.
Some might find this more comforting and therefore be more comfortable with rights.
I personally like lefts as it feels like I have better control of the throttle, whereas with rights you're countersteering and accelerating at the same time, which feels a bit jerky to me sometimes unless as high speeds. ____________________ Yamaha RXS 100 > Honda CD 250 > Honda Hornet 600 > Honda CBR 600RR > Yamaha RXS 100 > Kawasaki ZX6R J2 > Yamaha FZ1 |
| iooi |
 iooi Super Spammer
| gixerladsw |
| Rigga |
 Rigga World Chat Champion
 Posted: 21:40 - 29 Oct 2013 Post subject: |
I don't like right hand bends but love left hand bends. Wierd  ____________________ Current bike: Honda CBR 1100xx |
| Dave70 |
 Dave70 World Chat Champion
| bladerunner |
 bladerunner World Chat Champion
 Posted: 02:07 - 30 Oct 2013 Post subject: |
I used to find different people including myself will have a natural preference for either left or right hand bends...it's quite normal and I could spot it a mile away when instructing new bikers...ie maybe on a right hander they keep relaxed and are happy to move the upper body with the bike whilst negotiating the corner...same speed same road but left hander...the knee is coming out ....the upper body is stiff maybe pushing the bike down and sitting up a little with the arms stiff.....tells you straight away they have a lot less confidence in the bike. Once you know your doing this then you can make an effort to keep relaxed on your less prefered side....if that knee is wanting to stick out....your doing it wrong! As for tire wear....that should be down to the camber in the road here in the uk riding on the left and roads having the highest point in the middle for drainage...means left handers are banked with the corner so you don't have to lean the bike as far and right handlers the camber is against you so will work the tires harder at the same speed.....anyone who rides fast a roads will have loads of tread on the LHS of the front tire when the RHS is getting near the legal limit. As for race tracks....well them bits of Tarmac will normally have the whole width of the track banked towards the apex  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's
The last post was made 12 years, 340 days ago. Instead of replying here, would creating a new thread be more useful? |
