RS125 problems.. again!
Wiltie
PostPosted: 08:40 - 30 Oct 2013    Post subject: RS125 problems.. again! Reply with quote
Hello, in a matter of days my motorcycle has gone down the shitter Sad
When I was driving to work a few days ago my rev limiter started flickering about all over the place and was at times wasn't responding to anything (staying at 0rpm) whilst I was driving, after a few minutes my bike completely cut out. It wouldn't start up at all so I bump started it, had a complete loss of power and everytime I come to a stop it cut out even with my clutch held in.
I got it to work (just about) and it wouldn't start at all after that, so I changed the battery for a new one as it was losing power when put under pressure and it started to work fine.
Then... To add to the fun it happened again whilst I was at my mates house yet this time when I throttle it hardly responds to it. Bearing in mind my powervavlve jammed shut literally two days before all of this.
Any suggestions to what my problem is? I realise my carb is probably a bit blocked to start with, could my powervalve being jammed shut cause this? Any help will be appreciated. Thank you.
bikersupermot...
PostPosted: 10:12 - 30 Oct 2013    Post subject: Reply with quote
dont be adjusting any carb settings if the bike was originally running ok.
1st thing - new plug set to the correct gap. check / clean the air filter.
make sure battery is given a full charge and see how you get on with that to start with.
come back and let us know how u get on
tinybikes
Wiltie
PostPosted: 13:56 - 30 Oct 2013    Post subject: Reply with quote
Oh, so it'd be the spark plug needs changing? I didn't think it could be a possibility I was looking more technical, I assumed my carb was blocked.
Okay, cheers I haven't got time on my hands until Saturday so I'll let you know.
Wiltie
PostPosted: 14:05 - 30 Oct 2013    Post subject: Reply with quote
I have an idea. Do you not think it could be a fault with the generator? I don't think my battery is charging itself?
PostPosted: 16:02 - 30 Oct 2013    Post subject: Reply with quote
Get bike running, put multimeter across battery, you should see 14v~ if you do, its charging.
Minty
PostPosted: 16:16 - 30 Oct 2013    Post subject: Reply with quote
Check the choke is disengaging fully too. Had an issue on my NSR where it would bog down if I didn't keep it throttled. Turned out the cable was sticking and remaining permanently on.
My fingers smell of your mum.
PostPosted: 01:38 - 31 Oct 2013    Post subject: Reply with quote
So the bike ran increasingly badly until you changed the battery which fixed it for a while then it degraded again.
Sounds like the battery isn't charging (and I think a decently charging circuit is required on a later RS125). Stick a voltmeter over the battery. Should be ~12.5V with the ignition off, ~13.5V with the engine idling and ~14.5V with the engine being revved.
If you don't get readings like that then most likely the problem will be the regulator / rectifier, or the wiring to it.
The last post was made 12 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 64.59 Kb
