Indicator wiring
TomReilly
PostPosted: 20:31 - 31 Oct 2013    Post subject: Indicator wiring Reply with quote
As title says.
I got the front two working perfect, rear left is fine, but wherever I put the rear right it either does not come on at all, or just stays lit, does not flash, even when not indicating..
Wtf?
Motorcycle riding can be really cozy. If you want to be a little closer to your passenger, brake a little quicker for the next stop. Wink
andys675
PostPosted: 20:41 - 31 Oct 2013    Post subject: Reply with quote
there is no easy answer, somewhere the wiring is rubbing on the frame, or has a bad earth
check the wiring in places you've been fixing other stuff recently
moonzoomer
PostPosted: 21:50 - 31 Oct 2013    Post subject: Reply with quote
Bad earth or wrong size of lamp
DMCpro
PostPosted: 21:54 - 31 Oct 2013    Post subject: Reply with quote
Do you have a multimeter? Remove bulb and check voltage.
If you don't have a multimeter get one.
Honda CB-1, TS125X
VW Golf Estate
Nobby the Bastard
Harley Gaydar
PostPosted: 21:56 - 31 Oct 2013    Post subject: Reply with quote
Have you fucked about with the connectors at the rear? You shoudln't have the front flashing properly at the same time as the rear (on the same time) being on permanantly.
What is the rear light doing when the indicator is on?
Triumph Sprint ST 1050
TomReilly
PostPosted: 00:39 - 01 Nov 2013    Post subject: Reply with quote
Nono, the right left front and left rear flash the same time, but when indicating right the front right is fine but the right rear stays on perminent even when I switch the indicators off
If that makes sense
The last post was made 12 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.37 - MySQL Queries: 15 - Page Size: 47.07 Kb
