derbi 50 gpr, wont start on the button,
tymonbrig
PostPosted: 08:51 - 01 Nov 2013    Post subject: derbi 50 gpr, wont start on the button, Reply with quote
it will bump,but the power dies at low revs, it will pull and rev in the top rev range, i have fitted a new plug,
Formerly known as
P.
PostPosted: 09:28 - 01 Nov 2013    Post subject: Reply with quote
Well, the starters on these are shit anyway Laughing So might be needing one of those.
Does everything else work, lights etc? What happens when you press the button?
joef
PostPosted: 12:30 - 01 Nov 2013    Post subject: Reply with quote
Hows your battery? Sounds like it might be dead or weak.
Should be 12v when the bike is not running and 13v or more when running. The voltage should not drop much when trying to start, if it does then its weak and you could try charging it or replace it.
- 1981 Honda CB250N Superdream -
nathan k
PostPosted: 13:38 - 01 Nov 2013    Post subject: Reply with quote
the charging system on these bikes is shit, pre 05 bikes go through rectifiers like two stroke oil. In fact i might have some spares that would be of use to you.
first things first, what year bike do you have?
and do your dials die untill high revs?
try screwing in the idle screw, the middle big screw, see if that helps.
post a picture of your old plug too please?
The last post was made 12 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 38.2 Kb
