Guitar Amp Crackling with Headphones
J.M.
PostPosted: 12:20 - 01 Nov 2013    Post subject: Guitar Amp Crackling with Headphones Reply with quote
I was wondering if anybody could possibly explain this scenario to me and suggest a potential fix for it.
I have a guitar amplifier. It's done me well for a good couple of years now and still works alright. The sound isn't the best, but it works for practising at home. It's a Peavey Vypyr 30.
If I play it normally, without headphones, the sound is clear.
If I play with headphones, the sound through the headphones is clear but the speaker on the guitar amp itself creates a crackling sound.
I've attached an audio file to this post which demonstrates what I mean. The first 15s is the guitar amp with headphones plugged in, then I unplug the headphones, adjust the volume and play a few notes to illustrate clearness.
Does anybody know how what this is/how to fix this? Cheers Smile
2004 R1 & 2018 XSR900
bren_9311
PostPosted: 12:29 - 01 Nov 2013    Post subject: Reply with quote
Try removing all other wires away from the amp.
My opinion is neither copyrighted nor trademarked. If you like, I'll trade for one of yours.
Currently bikeless. Sad
Ps4- bren_9311
PostPosted: 12:40 - 01 Nov 2013    Post subject: Reply with quote
Hows the headphones cable routed? Does it hang by the front?
When I had the Vypyr... was when it first came out, was the smallest one you could get as rents hate noise Laughing I used some ghetto over ear headphones which caused an occasional hum through the speaker. Ended up turning the amp round and running the wires over the back, solved it until I bought a new amp.
oldpink
PostPosted: 12:48 - 01 Nov 2013    Post subject: Reply with quote
its more than likely a wire going to the speaker causing the problem or a bad solder joint
check the wires they are normally spade connectors make sure they have not become loose
if they are Ok you may need to take the amp section out its normally 4 screws on the top of the cab
trace the wires from the speaker to the circuit board and check they are Ok
try moving the wires about to see if it gets better / worse and take it from there
what happens when nothing is plugged in, does the amp still crackle
lihp
PostPosted: 12:49 - 01 Nov 2013    Post subject: Reply with quote
Does the speaker ground itself when you plug head phones in?
It could just be background noise, you can get a switched headphone socket, you then run the speaker cables to earth through it, so when you plug headphones in, it grounds out the speaker to prevent any unwanted noise.
J.M.
PostPosted: 13:05 - 01 Nov 2013    Post subject: Reply with quote
Have pulled all the non essential wires away, no better.
When nothing is plugged in, there is a slight humming noise. Nothing annoying. Same humming if I plug in the headphones but no input, but it quietens ever so slightly.
The crackling seems to appear only after the input has been plugged in and it has been played for a short while. The crackling will then remain for a short while after the input has been removed.
If I play with the input connected but no headphones, the sound is crystal clear. No crackling at all.
The crackling reminds me of the sound produced when you plug in/unplug headphones, so I wonder if it's possible that the joins on the headphone jack are loose or damaged? The input or the auxillary input doesn't seem to have this issue. I suspect that it's out of warranty now, so opening it up shouldn't be an issue.
lihp
PostPosted: 13:26 - 01 Nov 2013    Post subject: Reply with quote
Read my post, it's a cheap amp, so fairly sure the headphone socket won't be switched. To test this theory, connect the speaker wires to earth, and try again.
J.M.
PostPosted: 13:31 - 01 Nov 2013    Post subject: Reply with quote
I'm not sure exactly what you mean?
It seems obvious that if I disconnect the speaker, it'll stop making a sound, but it shouldn't be making it in the first place and didn't used to make the sound.
Or do you mean attaching an additional earth wire to the speaker?
All sockets and controls are in a self-contained head unit with only 2 wires coming out of it for the speaker and the transformer bolts directly on to the bottom of the head unit. To access anything else I'm going to have to remove and open up the head.
oldpink
PostPosted: 18:19 - 01 Nov 2013    Post subject: Reply with quote
possibly a bad earth on the input jack as it seems to be the culprate
take the amp out and give them a clean & check up
J.M.
PostPosted: 20:42 - 01 Nov 2013    Post subject: Reply with quote
Well, took off the head part. Everything looks perfect in there.
I guess it's a possibility that the actual input itself is faulty. Tempted to get the soldering iron out and switch the headphone and input jacks around.
Hetzer
PostPosted: 20:45 - 01 Nov 2013    Post subject: Reply with quote
Check inside the input and see if there's any cack in it.
The last post was made 13 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.14 - MySQL Queries: 13 - Page Size: 69.27 Kb
