Coils breaking
Marmalade
PostPosted: 17:42 - 01 Nov 2013    Post subject: Coils breaking Reply with quote
I've just fixed a Broken pan euopean, It died while moving, engine cut out and won't restart.
Plenty of power at the lt side of coils but a tiny spark on HT. Replaced the coil unit and it's all good but it is one bracket with 2 little coils on it.
Why would both pack up at the same time?
cb1rocket
PostPosted: 17:55 - 01 Nov 2013    Post subject: Reply with quote
Age and vibrations I would guess. Also the coils breaking up could of spike the other coil and broke that up too?
doggone
PostPosted: 18:27 - 01 Nov 2013    Post subject: Reply with quote
Are you able to test the voltage they are getting, if something else was giving out you could be getting intermittent big spikes.
It does seem suspicious, I've ridden a bike 300 miles home from Kent running on one coil and two cylinders, don't see any way the remaining good coil would get too much juice.
Marmalade
PostPosted: 18:35 - 01 Nov 2013    Post subject: Reply with quote
They work on a 3 wire mini loom with one supply and 2 neg pulses so i suppose it could spike with one breaking but highly unlikely.
It works now. I can send it back to the owner and see what happens.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:20 - 01 Nov 2013    Post subject: Reply with quote
Both failing at the same time? Very unlikely.
Is there any possibility it's been on one coil for a while and that the owner hasn't noticed the lack of power?
It's a Goldwing after all...
Triumph Sprint ST 1050
moonzoomer
PostPosted: 23:53 - 01 Nov 2013    Post subject: Reply with quote
Common coil fault normally means a common ground or earth fault , check any and all earth to chassis connections starting from the battery onwards and check the main earth connection between chassis and engine for corrosion. Also check the killswitch for wear and/or corrosion.
Marmalade
PostPosted: 09:51 - 02 Nov 2013    Post subject: Reply with quote
No it isn't. Have a try keeping up with a pan european sometime
Marmalade
PostPosted: 09:55 - 02 Nov 2013    Post subject: Reply with quote
The earth comes via the ecu/cdi with a common live on ignition.
The kill switch wires were soldered together and crimped some time ago because it was a little on the faulty side.
battery cables were all cleaned and greased along with replaced main relay back in the day and a new rectifier fitted.
It's not broken down for probably 20,000 miles but always electrical.
misscrabstick
PostPosted: 10:27 - 02 Nov 2013    Post subject: Reply with quote
No it's a pan European, nothing like a Goldwing at all, and you would notice if two cylinders packed up for sure.
Marmalade, I go along with the common earth fault, it's the only thing I can think of that would take out both coils at once, since they share a bracket, maybe they share a common ground point.
misscrabstick
PostPosted: 10:34 - 02 Nov 2013    Post subject: Reply with quote
Ohh had a thought some cars will shut down the ecu if a coil gets a funny resistance reading (broken coil), maybe the ignition control module got a weird voltage feedback from one bad coil and it shut down in protest making the other coil stop sparking too, I had this happen to a customers car once, a mazda mx5, one coil had shorted windings and the other stopped sparking too.
Marmalade
PostPosted: 20:59 - 02 Nov 2013    Post subject: Reply with quote
They are not that clever. the earth is via the ecu, constant live, coil activated by earth pulses.
misscrabstick
PostPosted: 21:02 - 02 Nov 2013    Post subject: Reply with quote
Taken any primary/secondary resistances?
Marmalade
PostPosted: 21:51 - 02 Nov 2013    Post subject: Reply with quote
didn't bother, just chucked them in the shed
Easter Bunny
PostPosted: 14:22 - 09 Nov 2013    Post subject: Reply with quote
You'll forget they don't work!
Marmalade
PostPosted: 18:02 - 09 Nov 2013    Post subject: Reply with quote
I took the caps off the ht leads so i'd know. I'll test them eventually but the fact the bike works and has done several hundred miles since says i was right to change them.
Easter Bunny
PostPosted: 09:40 - 10 Nov 2013    Post subject: Reply with quote
Yes you are indeed a star.....cheers Karma Thumbs Up
Walloper
PostPosted: 18:04 - 10 Nov 2013    Post subject: Reply with quote
I had two 'in-line' ignition coils shit their sel' in one trip home.
Water damage was what finally did the damage Shit build quality was the root cause. I had one of the same things fail on a 2nd bike smae model, age an mileage.
It seems strange for two to go at once but if more than two are doing the same work for the same time then paerhaps situations can gang up on them. Smile
The last post was made 12 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 100.91 Kb
