Tailgating
CustomDan
PostPosted: 15:08 - 02 Nov 2013    Post subject: Tailgating Reply with quote
Hi, This question has probably been asked many times...
What is the best way to deal with a tailgater?
Usually I will just pull in and let them past, But sometimes this is not safe. On my little 125 I am not usually going fast enough to slow down and cant really go much faster to gain any significant distance-(which is not a good idea anyway)
I have even resorted to looking back at the tailgater in the hope they might realize that their driving is a danger to me. But if that was the case then they would not be driving so close in the first place.
I have even had the stupid idea of slowing down enough then slamming my breaks on! obviously, I am not going to do that tho Confused
any advice?
Hetzer
PostPosted: 15:11 - 02 Nov 2013    Post subject: Reply with quote
Come off the throttle, clutch in and come slowly to a stop in the middle of your lane. They'll either go around you or they'll get out and you can have words.
The next car coming might wipe you out though. Neutral
Andy_Pagin
PostPosted: 15:20 - 02 Nov 2013    Post subject: Reply with quote
Vary your speed using only the throttle, nothing drastic, just enough to keep then swapping from accelerator to brake, usually they get fed up with continually having to think about what they're doing and back off.
gbrand42
PostPosted: 15:43 - 02 Nov 2013    Post subject: Reply with quote
Slow slightly to increase distance to the car in front, hopefully this will reduce the chances of you having to slam on the stoppers and have the bell-end steam over you from behind.
berzerker
PostPosted: 15:45 - 02 Nov 2013    Post subject: Reply with quote
Pull in and let them pass.
An idiot in front of you is easier to deal with than one behind you.
Lupo
PostPosted: 15:46 - 02 Nov 2013    Post subject: Reply with quote
With the car, I usually press down the brake pedal slightly, so my braking lights come on, it is and automatic response to any driver to press their brake when that happens.
A por ellos, que son pocos y cobardes.
CustomDan
PostPosted: 17:05 - 02 Nov 2013    Post subject: Reply with quote
Cheers Smile Lots of food for thought
YBR Ric
PostPosted: 19:13 - 02 Nov 2013    Post subject: Reply with quote
I either pull in or gradually slow down in an attempt to match my speed to their braking distance.
In the case of the latter, they eventually back-off or overtake, either way I'm happy.
adam277
PostPosted: 19:16 - 02 Nov 2013    Post subject: Reply with quote
Lightly tap your brake light several times so you tell them to back the fuck down or you will fuck them up in morse code.
Christoffee
PostPosted: 20:03 - 02 Nov 2013    Post subject: Reply with quote
Don't let the bastards pressure you. Your responsibility is to not crash and not hit the car in front. Don't exceed your own or the bikes limits to try to make the guy behind happier.
Bike: CBF125
Teflon-Mike
tl;dr
PostPosted: 20:19 - 02 Nov 2013    Post subject: Reply with quote
Tail-Gaters - Back-Off
DON'T REACT - DON'T ENGAGE
Do NOTHING!
There's fucking idiots every-where; so you have one behind... there's ALWAYS an idiot behind you somewhere..... this one? Well, you have spotted this one; so fuckem. They are dealt with. Dont obscess about them, don't try and 'make' them do anything; thats the same as them trying to make YOU do something... worry about riding your bike; not them! They are just ONE of many many hazards that need your attension and you now know they are there; they dont need much more, and they sure as fuck dont need the attension you should be paying to the twenty million other bludy idiots out there you HAVEN'T spotted.... yet!
But follow link; read advice.
PostPosted: 12:08 - 03 Nov 2013    Post subject: Reply with quote
Boils your piss, right?
So be aware of that, because that you'll get less rational the longer that you allow it to go on, and will make daft decisions.
Pull over ASAP or in extremis just come to a stop gradually in the lane and signal them to go around. I've only had to do the latter once, due to Postman Prat driving literally inches off my rear wheel.
It's not worth engaging with them. If they were reasonable or capable of self awareness, they wouldn't be endangering your life in the first place in return for shaving zero seconds off of their journey.
trevor saxe-coburg-gotha
PostPosted: 12:31 - 03 Nov 2013    Post subject: Reply with quote
I'm out on 125s regularly enough and for me the answer depends in part on the kind of road, and to some extent also the conditions and time of day. On an A road in decent conditions I'll be mirror checking a lot, always getting an idea of what's approaching, how fast, what kind of vehicle. If it looks fairly normal, being driven competently I get right over, early - which is meant to send the message "I'm not and or can't go any faster so here - have 95% of the road and fuck off." The intention being to nip any arse fondlers in the bud before they even get the idea. Most of the time this works and I often get an acknowledgement - a wave or two flashes of hazards, whatever.
At night or in rain though, or on narrow roads, I do what tef said. There are a great many deep, dangerous pot holes at the sides of the roads around here which when full of water are almost invisible. I'm not going to hit one of those.
Turkish
PostPosted: 17:22 - 03 Nov 2013    Post subject: Reply with quote
Increase the distance between you and the car in front and pull over when it is safe to do so.
These knuckledraggers have already demonstrated they are not capable of intelligent thought so slowing down for no reason, brake checking, flashing brake lights and so on will just help bring out the neanderthal tenancies.
Plus there is nothing more satisfying than filtering past these muppets a mile down the road.
ZX-6R G2
CBR125R RW6
Hefty
PostPosted: 12:00 - 04 Nov 2013    Post subject: Reply with quote
Turkish wrote:
Pull over when it is safe to do so.
+10,000 xp Thumbs Up
'13 Honda CBF125 // '99 Suzuki SV650s // '98 Honda CB600F Hornet
nathan k
PostPosted: 12:16 - 04 Nov 2013    Post subject: Reply with quote
There's two ways to deal with it, method one is for helmet cameras.
-press your rear brake pedal just so the light comes on
-Turn around and do the "back up" hand thing.
-If problem persists turn around and do the "fuck off!" thing.
-Wait till traffic slows and make a Russian road rage style video. Thumbs Up
No camera evidence and no wish to die, any of the following:
-Take a turning or extra loop around a roundabout
-Pull over only where safe
-Slow a little more, and wave them through to pass you when safe.
-Ignore them and counter effect it with more braking distance between you and the car in front, hopefully this will encourage them to pass too.
Ribenapigeon
PostPosted: 13:15 - 04 Nov 2013    Post subject: Reply with quote
Keep your distance from the vehicle ahead, if you can't pull over this saves you from the double danger of getting sandwiched. As others have said, don't let other road users pressure you, go at your own pace.
thx1138
PostPosted: 18:48 - 04 Nov 2013    Post subject: Reply with quote
I ride slower, so they pass me, I don't shout or gesture or even look at them, as I don't want any aggro from a nutter, just want them gone.
Notj7
PostPosted: 22:39 - 04 Nov 2013    Post subject: Reply with quote
This is why I don't like either being on a 125 or being in the car - you just get tailgated all the time. Never mind the '4 second gap' that's needed in wet weather. Even family members are guilty of this, they drive way way too close to the car in front and don't listen to me: "I've been driving 30 years and I've never hit anyone". Rolling Eyes
Being on a 600 sorts all that out. 25mph, 1st gear ----> 60 in about a second and a half Wink
Left the forum.
dydey90
PostPosted: 23:02 - 04 Nov 2013    Post subject: Reply with quote
I like to stick strictly to speed limits and suddenly turn into Mr. Thoughtful. Let everybody out of junctions, stop at amber lights, make sure to take every bend nice and slowly.
Nobby the Bastard
Harley Gaydar
PostPosted: 23:21 - 04 Nov 2013    Post subject: Reply with quote
I do make a point of looking out for smaller capacity bikes (especially if the have L plates on them) on my journeys and if they are being tailgated, I'll pull into their lane beside them and then back off, pushing the tailgater backwards.
For some reason a big, fast bike slowing them down gets the message across and and they back off. If they don't, I wait until I've opened up a gap from the other bike and then engage warp speed...
Triumph Sprint ST 1050
thx1138
PostPosted: 16:51 - 06 Nov 2013    Post subject: Reply with quote
yeah, leave a sensible gap, someone fills it.
repeat, ad naseum
feels like you are riding backwards down the road at times
The last post was made 12 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.66 - MySQL Queries: 13 - Page Size: 113.56 Kb
