| burnsy |
 burnsy Derestricted Danger
 Posted: 22:12 - 23 Oct 2013 Post subject: 1996 aprilia rs 125 extrema |
Hi guys iv posted in the new bikers section so please do say hi!
1996 aprilia rs 125 extrema (extrema meaning im the fastest bike on the road lol )
right it starts, runs, and rides ok. 28mm carby on there (rarrr!!) has some stainless end cane on it (birds love that ) other than that I think its in standard trim in being full power.
NOW! when riding all seems well, but full throttle giving it some bean on a B road around 50mph engine dies dead, let off the throttle and straight back on its ok again, or when I change gear its ok again...but only happens when I ask for the full beans? doesn't feel as fast as other have said it should be.
there was a oil leak when I got it a couple of months ago, on which has been booked in for repair (power valve gasket was wrong way round or something) £65 later and still have a leak just not as bad as before. main jet in carb is 120.
any ideas would be greatfull |
| kerr |
 kerr World Chat Champion
| evoboy |
 evoboy World Chat Champion
 Posted: 22:28 - 23 Oct 2013 Post subject: |
Sounds like the main jet is too small/its running lean at full throttle.
Does it sound like its running out of fuel when you give it full?
Does it have the airbox on it or a paper pod filter?
Is it just the end can that has been changed or the whole system? ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| Kickstart |
 Kickstart The Oracle
| burnsy |
| Kickstart |
| burnsy |
| nathan k |
 nathan k Spanner Monkey
| burnsy |
| nathan k |
| stirlinggaz |
 stirlinggaz World Chat Champion
 Posted: 21:02 - 24 Oct 2013 Post subject: |
hi,
the bigger screw is usually the idle screw, which actually controls throttle/slide height.
smaller screw nearest air filter end is air mixture adjust screw,
smaller screw nearer engine is fuel mixture adjust screw.
if any of them are missing, carb wont work correctly. could get away with throttle stop screw being missing, would just be difficult to get it to idle correctly.
if air/fuel mixture screw is missing, replace it with one from here https://www.dellorto.co.uk/merchandise/products.asp?CategoryID=2&PartsectionID=24
cheers,
GAZ |
| Kickstart |
 Posted: 21:10 - 24 Oct 2013 Post subject: |
There are 2 screws. One controls the idle speed by providing a stop for the throttle slide. With this missing the idle speed will be low, and possibly it might be a touch lean (but probably not by much).
The other controls the idle mixture. If this is missing the mixture will be totally screwed at idle (probably less so at higher speeds / throttle positions). Don't just replace this with any random bolt as the shape of it will control the flow of air / fuel throw the idle circuit.
| burnsy |
| Kickstart |
| burnsy |
 Posted: 18:24 - 26 Oct 2013 Post subject: |
right its in the bin!! it wasn't the right carb for my bike anyway so its in the right place lol
34mm flatside carb has been ordered with manifold and racing reeds (might aswell while im in doing things)
bought items from a guys breaking his rs125 racebike which carb ect was all set-up. Hopefully this will get the aprilia running right, then exhaust to finish things off. Should be around the 30bhp mark or there abouts.
does anyone know if the 96 extrema's have restricted CDI units in place as I defo have a massive flat spot between 5-6k, but thinking this could be down to the dodgy carb also.
kickstart! you have a sensible aprilia rs 125 anything I can do for the bike to improve reliability and maybe slightly bit more power. when I had the powervalve serviced last week guys said there was two small scores on the valve itself but didn't think this would make any difference to performance (should I replace it anyway?)
regards Burnsy |
| Kickstart |
 Posted: 18:41 - 26 Oct 2013 Post subject: |
They have no separate cdi on the older style Rotax 123 engined bikes. The ignition is contained in the stator and the coil (with just a wire to earth out the ignition to stop the engine). There is no restriction in the ignition (that came with the 122 engined bikes).
However you can adjust the ignition timing, and entirely possible someone has done that already, and made a mess of it. Note they were originally set up for high octane petrol.
There shouldn't really be a flat spot between 5k and 6k, although as with many performance 2 strokes a bit of a flat spot just before the power band isn't uncommon.
The power valve should be fine (just make sure it is the right way up, people commonly put them in upside down).
Not really anything simple to increase power. You could try a different exhaust (but the stock one is pretty good), or get someone like Mick Abbey to play around with the barrel and head. But both will probably give more set up problems and neither will improve reliability. Most important thing is to not thrash the engine from cold.
| burnsy |
| stirlinggaz |
 Posted: 16:38 - 02 Nov 2013 Post subject: |
hi,
pretty sure i ran 34mm carb with 162 main jet.
when you changed the carb over, did you replace the manifold?
there are 2 different sizes, 1 for 28mm, other for 34mm.
does the manifold look cracked? it may well have a small split.
are the jubilee clips tight?
check it with a can of wd40 or similar.
spray it onto the manifold whilst bike is idling, & if revs climb, then you need a new manifold, although i have repaired a few, with sealant (granville black gasket stuff. which dries to a rubbery solid, just like mastic).
cheers,
GAZ |
| Kickstart |
 Posted: 17:41 - 02 Nov 2013 Post subject: |
Sounds a bit large for a 34mm carb, although within reason. Think they are normally around a 155, although it does vary a bit with the exact model.
Check for air leaks in the intake as above (note that worn main bearing seals can also cause a high idle, but 6000rpm idle would likely require a very knackered seal), but also check that the idle speed screw is set OK.
| burnsy |
| Kickstart |
| burnsy |
 Posted: 20:22 - 02 Nov 2013 Post subject: |
thanks keith!
the only problem now is its idle slightly lumpy and every now and again it will stall once throttle is open, but past 2k it rev's lovely and a lot more freely than before.
could this be that reed not closing fully, as you say hard starting normally. 1500rpm to 2k bogs down sometime dies. but past 2k revs nice.
black oil leak now too onto exhaust chamber. this bike loves to give me things to do lol must be exhaust manifold as powervalve has just been serviced
burnsy |
| Kickstart |
 Posted: 20:32 - 02 Nov 2013 Post subject: |
You can clean up the oil where the exhaust joins to the barrel. Think it is meant to be sealed with high temp silicone sealant (is where the exhaust goes over the ball shape stub).
Suspect the reed valve leaking could cause the stalling. Look carefully at the reed and check it hasn't moved slightly (ie, with age the reed can leave an indentation in the rubber of the reed block, then if the reed is moved slightly it no longer fits in the indentation).
| burnsy |
| burnsy |
The last post was made 12 years, 56 days ago. Instead of replying here, would creating a new thread be more useful? |
