Throttle
Dan 4RR
PostPosted: 21:14 - 18 Dec 2004    Post subject: Throttle Reply with quote
Does anyone know why the throttle is on the right hand side of the handle bars and not the left?
Can you buy specialised/personalised bikes that have everything on the left? Just curious , thanks.
Azmodeus
PostPosted: 21:42 - 18 Dec 2004    Post subject: Reply with quote
The only feasable reason I can come up with is balancing.
At the moment, you have front brake/throttle, and rear brake/clutch
If you moved the throttle only, it would be rear brake/throttle/clutch. Not a good combo.
If you switched the clutch too, it would mean you have both brakes on the left hand side, and it would unbalance you.
So the only way to do it would be to literally swap everything (front brake/throttle/back brake/clutch)
TiN
Pocket Tin
PostPosted: 21:44 - 18 Dec 2004    Post subject: Reply with quote
It's very possible to get a bike modified for such a setup, but I can't imagine that it'll be easy to find one for sale like that.
The only thing to really stop you from just lobbing the thottle assembly onto the other of the handlebars could be the length of the throttle cables...and possibly the throttle tube itself, as it may turn the "wrong" way...
TiN
dotgems.net
mchaggis
PostPosted: 22:06 - 18 Dec 2004    Post subject: Reply with quote
I would imagine that the throttle is on the right simply because most people are right handed.
I must not be a troll...
Mmmm, Guinness
Lone-Wolf
PostPosted: 00:21 - 19 Dec 2004    Post subject: Reply with quote
Wotcha.
Today's useless trivia.
American made "Indian" police motorcycles had the twistgrip on the left hand side - this left the rider's right hand free to use his gun.
Cheers.
L.W. - www.moonshiners.org.uk
Azmodeus
PostPosted: 00:33 - 19 Dec 2004    Post subject: Reply with quote
But what if the officer was left handed? (And therefore could only shoot with the gun in his left)
Mantzy
PostPosted: 00:50 - 19 Dec 2004    Post subject: Reply with quote
Best person to ask would probably be Born2Bvile, as a member of nabd (National Association for Bikers with a Disability) he could tell you. Though, if you're fully abled, why would you change it?
Or was this just a Idea moment?
Edit: https://www.nabd.org.uk/adaptions/javaindex.htm - Look here.
Current Bikes: 2010 Triumph Sprint ST 1050
Previous Bikes: 2002 Sachs XTC, 1999 Kawasaki ZX6R, 2004 GSX-R 600 K4, 2006 Yamaha XT660X
dandit
PostPosted: 06:19 - 19 Dec 2004    Post subject: Reply with quote
my dads mate lost his arm at the elbow I think and he had is bike converted so all controls on 1 side and had a mental arm made up even had a damper on it that clamped round the handle bar how he rides it I do not know I know his arm was more expensive than the bike though because it was lightwieght maybe carbon and had dampers fitted to stop his shoulder hurting
WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE I STILL HAD 3 GEARS TO GO OFFICER. Currently riding a naked cbr 600 and driving a 52 plate 2litre tdci mondeo
aqualung1
PostPosted: 10:40 - 19 Dec 2004    Post subject: Reply with quote
just as mantzy said
"still no idea where poohsticks bridge is"
www.bosunsbikes.com
PostPosted: 12:08 - 19 Dec 2004    Post subject: Reply with quote
Another piece of useless trivia. Motorbikes didn't always have twist-grip throttles. My mates pre-war BSA has a bowden lever on the top of the bars, like the throttle on a petrol lawnmower...Actually, it has three, the throttle, ignition advance and fuel:air mixture, add in the hand gear shift, valve lifter and brake levers coming from the outside ends of the bars and it is a bit like trying to juggle six balls whilst riding a bike.
I have seen a bike that had ALL the controls except the gearshift on the left bar. Throttle, brake lever angled from the inside, clutch lever angles from the outside and a thumb rear brake, as well as all the light and indicator switches.
PostPosted: 13:24 - 19 Dec 2004    Post subject: Reply with quote
Suspect there is probably some international standard now that specifies the throttle is on the right. Most bikes used to have the gearchange on the right but that changed in the mid 1970s when the USA legislated that the gearchange must be on the left.
mchaggis
PostPosted: 13:28 - 19 Dec 2004    Post subject: Reply with quote
That's a little bit like a quad? I've not seen many but I'm sure I've seen some with lever operated throttles. You just can't beat a petrol lawnmower.
Mmmm, Guinness
Lone-Wolf
PostPosted: 13:30 - 19 Dec 2004    Post subject: Reply with quote
Wotcha.
The he would ride the Harley Wink
Cheers.
loply
PostPosted: 18:17 - 19 Dec 2004    Post subject: Reply with quote
Surely its obvious?
If the throttle was on the left then you would not be able to roll off at the same time as operating the clutch, a neccessary movement if you want to change up gears...
And vice versa you couldnt blip to go down.
Yamaha SZR660 Caution to the wind, the throttle pinned!
pipnet11
PostPosted: 18:26 - 19 Dec 2004    Post subject: Reply with quote
Surely its obvious?
This would be the reason Id suggest.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
PostPosted: 22:58 - 19 Dec 2004    Post subject: Reply with quote
There is a reason for the gearchange thing. British bikes always had it on the right, european and american on the left. This is because it is easier to take the rear brake accross to a sidecar (on the appropriate side of the bike) if it is on the same side as the chair.
My 1971 suzuki T500 has the facility to fit them on whichever side you preferr.
Rob W
PostPosted: 23:05 - 19 Dec 2004    Post subject: Reply with quote
Agreed. Would be my answer anyway.
PostPosted: 09:24 - 20 Dec 2004    Post subject: Reply with quote
Plenty of Italian bikes had a r/h gear change. Check some of the horrendous linkages used on (for example) Moto Morinis to swap the gearchange over to the left.
The last post was made 21 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 102.15 Kb
