Carb set up
Stuwickwar
PostPosted: 18:49 - 04 Nov 2013    Post subject: Carb set up Reply with quote
Does anyone know how to set up the carb on a suzuki gp100 the carb is a mikuni vm22ss. Can't find a guide on the carb anywhere identifying what to alter. Help appreciated.
burnsy
PostPosted: 22:37 - 04 Nov 2013    Post subject: Reply with quote
whats the problem with the carb dude?
Stuwickwar
PostPosted: 22:41 - 04 Nov 2013    Post subject: Reply with quote
Had a problem where the bike was ticking over for a few minutes then suddenly revving up to red line and cutting out thought it might be carb set up. Bike wouldn't start again after it did it a few times. And today I was trying to kick it up and suddenly fuel starts pissing out from between the crankshaft and the gearbox. Think a seal has split! Having an absolute nightmare!
DMCpro
PostPosted: 11:29 - 05 Nov 2013    Post subject: Reply with quote
I think your crank seals have blown fix the serious mechanical faults first
Honda CB-1, TS125X
VW Golf Estate
stirlinggaz
PostPosted: 14:41 - 08 Nov 2013    Post subject: Reply with quote
hi,
theres a couple of good guides available on t'internet this is particularly useful https://www.mikuni.com/pdf/vmmanual.pdf
theres others, but cant remember where i last saw them (i have them saved on cd somewhere)
easy carbs to work on imho,
cheers,
GAZ
DMCpro
PostPosted: 21:07 - 08 Nov 2013    Post subject: Reply with quote
Drain the gearbox oil out and smell it tell us what it smells like
Honda CB-1, TS125X
VW Golf Estate
bladerunner
PostPosted: 03:15 - 09 Nov 2013    Post subject: Reply with quote
if you mean fuel is pissing out between the crank case halfs where the crank is(rather than at the rear/gearbox side then you then youll be getting a serious air leak and running lean causing the rise in revs......post up a pic of where the fuel is coming from if you can!....its a motor out and apart job to fix if it is.....lucky its a gp100 if it is as the fix will cost you about £30 and half a days work to fix if the casings are ok
Stuwickwar
PostPosted: 19:04 - 19 Nov 2013    Post subject: Reply with quote
Thanks for the replys. I've replaced the gaskets on the crankcase and clutch. I saw the fuel was leaking from that gasket so I've replaced it. Since I've replaced them the bike isn't starting now. I'm getting frustrated with this bike now needed it for work and struggling to get it running. Might have to reluctantly take it to a mechanic Sad
The last post was made 12 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 54.65 Kb
