knocking leant over after gearbox rebuild
Snorty This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
pepperami
PostPosted: 22:12 - 06 Nov 2013    Post subject: Reply with quote
Thrust washer missing?
Different parts from different model or year? (specs change)
All gears select fine and no knocking when in gear.
Gear box ok , clutch ?
EDIT : try asking this in Workshop?
uberkron
PostPosted: 05:01 - 07 Nov 2013    Post subject: Reply with quote
Did you disturb any engine mounts doing this job? The sidestand being involved sounds odd. I also tend to think that gravity would not have that much influence on an engine/gearbox.
i ride a zip 50 2smoke. It overtakes a hundred times a day.
uberkron
PostPosted: 05:02 - 07 Nov 2013    Post subject: Reply with quote
iooi
PostPosted: 06:59 - 07 Nov 2013    Post subject: Reply with quote
NO, But taking bits of it out of the oil will....
Snorty
PostPosted: 11:20 - 07 Nov 2013    Post subject: Reply with quote
It knocks when leant to the left only. Only in neutral.
It's a very distinct knock noise. Single knock repeatedly when leant over on the left side in neutral only.
Motor is getting opened up again today, to have a look at the transmission again as this knock wasn't present before the transmission was replaced.
m3-paul
PostPosted: 14:09 - 07 Nov 2013    Post subject: Reply with quote
Something to do with the shift drum moving very slightly when in the neutral position? Can't imagine how a shift drum would have the ability to move in a sideways fashion but worth checking I guess.
Yamaha TZR250 - love the smell of TTS!!!!
CBR900RR Fireblade - so much fun
The Disapproving Brit
PostPosted: 14:32 - 07 Nov 2013    Post subject: Reply with quote
Can't help, but I have almost the exact same issue, except mine persists in gear. I'd be interested to know what you find.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
Paddy Blake
PostPosted: 14:44 - 07 Nov 2013    Post subject: Reply with quote
I would have put the drum and forks from the new gearbox in aswell.
Check the numbers on both sets of forks and see if they are different.
stickybackbob
PostPosted: 17:58 - 07 Nov 2013    Post subject: Reply with quote
No chance of one of the gear wheels being put in the wrong way round?
Some gears (without the dogs on) can appear to go in either way when in reality, they only work properly one way round Smile
Snorty
PostPosted: 21:36 - 09 Nov 2013    Post subject: Reply with quote
Old selector forks were worn away... put new ones in which are mint.
The noise persists! No idea what it could be now, but as it's only when the bike is leant to the left in neutral I'll put up with it for now...
Gearbox is so smooth regardless.
_mjs_
PostPosted: 22:49 - 09 Nov 2013    Post subject: Reply with quote
Probably a long shot, but have you looked at an exploded diagram to make sure you're not missing a washer or ball bearing somewhere?
Paddy Blake
PostPosted: 23:23 - 09 Nov 2013    Post subject: Reply with quote
Just thinking the only time I came across this problem was when a garage left out the half-ring retainer from the bearing behind the clutch.
This allowed the shaft to move in neutral and caused that noise.
In gear the forks stopped the shaft from moving.
Any chance you left half-ring out.
There is a gap of 1 year, 211 days between these two posts...
metalizzer
PostPosted: 23:11 - 09 Jun 2015    Post subject: Reply with quote
hi
got to dig this topic up from the grave... i´m experiencing exactly the same thing with a xrv 750 after engine rebuilt . only does the noise on neutral on the stand... did you solve the problem! it´s driving me nuts!
Snorty
PostPosted: 12:25 - 10 Jun 2015    Post subject: Reply with quote
To be honest, I've just ignored it. I am going to split the gearbox at some point when I get a spare weekend, could be what Paddy said, or something else.
Not sure if there is some kind of thrust washer I may have left out.
spikenipple
PostPosted: 15:01 - 10 Jun 2015    Post subject: Reply with quote
Vincent wrote:
I'm pretty sure these are fitted to each gearbox and can vary on different engines of the same bike.
Correct.
Each component in the gearbox is manufactured to a given size tolerance. One good component might be (size)-0.1mm, whilst another good part might be (size)+0.1mm.
The end float (axial movement) of the shaft carrying these components must sit within a given tolerance, which is considerably smaller than the stacked max/min tolerances of all of the components on the shaft.
An appropriately sized thrust washer is fitted to bring the end float back to within the correct tolerance.
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
metalizzer
PostPosted: 17:03 - 10 Jun 2015    Post subject: Reply with quote
you guys are saying that everything probably is correctly mounted but it can be a washer out of specs? i did open the engine because of a worn output shaft but all the spline washers and cir clips on the new shaft are from the old one.
i took special attention assembling the shaft every gears or washers before assembly on the shaft i looked on the manual to see the corect position.
if you look at a parts manual for the XRV 750 all engines interiors are the same and have the same honda number parts no matter the year of the bike
metalizzer
PostPosted: 20:57 - 10 Jun 2015    Post subject: Reply with quote
Vincent wrote:
If I understand it correctly, when the gearboxes are assembled, the end float is measured and the appropriate shim used to get it to within spec. Your using a shaft and box that havn't been measured together. It could be that your replacement shaft needs a thicker washer with the old box.
you are saying that the washer between the shaft and the cases have to be thicker? is it this washers (22 & 25) on the link below?. if so there are no references about thicker or thinner washers on the manual or honda parts.
https://www.cmsnl.com/xrv750-africa-twin-1993-netherlands_model7065/partslist/E__1500.html#row23461MY1000
thanks
metalizzer
PostPosted: 21:08 - 10 Jun 2015    Post subject: Reply with quote
[quote="Snorty"]To be honest, I've just ignored it. I am going to split the gearbox at some point when I get a spare weekend, could be what Paddy said, or something else.
yes, that´s what people keep telling me. but i fallowed every step on assembling the shaft by the bike´s shop manual. the washers and cir clips have a correct position to be mounted on the shaft that´s why i took so much care.
how do you ride the bike??? you have always to be careful not to start it on the side-stand or lean it to the left on neutral!
metalizzer
PostPosted: 23:39 - 10 Jun 2015    Post subject: Reply with quote
what i could of done wrong was probably assemble one or more thrust washer and snap rings on the wrong position since they are chamfered (rolled) and must be installed facing away from the thrust load! can this be it? i remember being a bit confused about this
metalizzer
PostPosted: 16:58 - 11 Jun 2015    Post subject: Reply with quote
yes , i´could´nt even do it without the manual.
The last post was made 11 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 127.99 Kb
