RS125 Idling Issues
sinedtomuch This post is not being displayed because the poster is banned. Unhide this post / all posts.
nathan k
PostPosted: 11:29 - 07 Nov 2013    Post subject: Reply with quote
I'd start with these two:
High idle speed? I'm not sure what carb you have but normally the center screw is the idle speed, turn it out to lower the speed.
Snagged throttle cable? Turn your bars full lock left and right to see if it's getting caught.
Formerly known as
P.
PostPosted: 11:49 - 07 Nov 2013    Post subject: Reply with quote
If the idle screw does nothing, maybe its not the idle screw. Laughing
But no, cracked inlet? Your idle should be 1400 when warm and about 3k on choke.
nathan k
PostPosted: 12:09 - 07 Nov 2013    Post subject: Reply with quote
Spray starting fluid -insert flammable spray able alternative here- on places where you think there could be a air leak, if these is indeed on then the RPM's will rise.
Formerly known as
P.
PostPosted: 12:30 - 07 Nov 2013    Post subject: Reply with quote
Then something is obviously fucked... choke should be required in the cold weather. My RS would not start unless it was on full choke in 5 degree weather.
Formerly known as
P.
PostPosted: 18:04 - 07 Nov 2013    Post subject: Reply with quote
Might be running lean..
The last post was made 12 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 65.27 Kb
