Throttle cable
fuzz
PostPosted: 14:46 - 19 Dec 2004    Post subject: Throttle cable Reply with quote
After recently having my clutch cable snap, (not while on the road luckily) and fitting a temporary one till I can get the part, I was wondering about the throttle cable. Should there be some slack before the cable acts on the slide (only a few mm), or should it open up from the instant you twist the grip? I know you can adjust it but I'm not sure if it's possible to overtighten or whether it does need adjusting at all.
PostPosted: 14:49 - 19 Dec 2004    Post subject: Re: Throttle cable Reply with quote
It shouldn't be possible to 'overtighten'... this will just adjust the idle speed as such. The throttle cable isn't under much pressure, so shouldn't be a problem.
Any slack is down to personal preference, I try to have no slack if it's a bike that's going to be ragged a bit.
The last post was made 21 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 31.38 Kb
