What is this and how do I fix/clean it?
David072
PostPosted: 09:53 - 08 Nov 2013    Post subject: What is this and how do I fix/clean it? Reply with quote
Hey Guys,
I've got these black marks on the bars of my Fazer. They don't seem to rub off - any idea whats causing them (assumeit'll be a key rubbing?) and how I can clean it?
https://i43.tinypic.com/i76jja.jpg
Cheers!
David
Hetzer
PostPosted: 09:55 - 08 Nov 2013    Post subject: Reply with quote
Parafin or, more aggressive, lighter fluid?
pdg
PostPosted: 10:04 - 08 Nov 2013    Post subject: Reply with quote
To clean it - you might not be able to... If you can feel the marks with a fingernail but they don't come off then they're scratches...
Stop it happening again by not having a jailer's keyring - just the bike key goes in the bike.
BTTD
PostPosted: 11:01 - 08 Nov 2013    Post subject: Reply with quote
I use a keychoob, although I've modded mine by cutting it open, sewing a loop of string down the spine to attach a split ring to and velcro to close it back up. Within the choob is the key to my disc lock, and a small plastic tab with tyre pressures written on it.
Make your own with an scrap of neoprene if you have any.
https://www.keychoob.co.uk/
Walloper
PostPosted: 13:33 - 08 Nov 2013    Post subject: Reply with quote
The bars/Top Yoke is aluminiumumumum alloy painted silver colour.
The only way to get those 'abuse' Razz marks out is by using a cutting compound (course paint polish) and try to rub out the marks. It will take a microscopic layer of the paint off and any lacquer though.)
If impossibru to rub out they will need repainting if you want to 'Go Full-Anal' on them.
As said ^^^ you only need the key for the bike and just the key for the bike in there. Put the keys to your penthouse apartment/mum's house somewhere else.
fatjames
PostPosted: 14:52 - 08 Nov 2013    Post subject: Reply with quote
Try a bit of solvent, like brake/clutch cleaner or maybe bug/tar remover or what he said.
BTTD
PostPosted: 16:17 - 08 Nov 2013    Post subject: Reply with quote
I had a not dissimilar issue, bars were marked from handguards and gps mounting. Further cleaning / t-cutting just made the marks worse, so:
Get some masking tape and lots of newspaper. Cover everything except the affected area. Find an old half full can of silver spray paint (Ford Moondust silver) and give is a spray. Not too many coats, just enough to make it disappear. Once it's almost dry (because you're impatient) remove all the tape and newspaper. Stand back in surprise at what a good match the colour is and that it actually looks better rather than worse.
David072
PostPosted: 17:06 - 08 Nov 2013    Post subject: Reply with quote
Cheers for your help guys!
I only have one key on with my bike so thought it'd be OK, I'll remove it now!
Will give it a good scrub tomorrow and if that doesnt work look at maybe trying to spray it...
PostPosted: 17:13 - 08 Nov 2013    Post subject: Reply with quote
It wouldn't even occurr to me to clean off marks like that. I have many hundreds of better things I could be doing with my time.
I suggest you ignore them and go and do something more fun or usefull instead.
pepperami
PostPosted: 17:36 - 08 Nov 2013    Post subject: Reply with quote
What Stinky said! +1
The last post was made 12 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 63.07 Kb
