Kawasaki GPZ500s
Steve O
PostPosted: 17:10 - 19 Dec 2004    Post subject: Kawasaki GPZ500s Reply with quote
Can anyone tell me where the coolant filler is, I havn't used the bike yet & after a quick glance the filler spout is not in the obvious places?
Regards Steve
rizo-sri200
PostPosted: 18:23 - 19 Dec 2004    Post subject: Reply with quote
Under the tank Question
Thats where mine is anyway Thumbs Up
swift kick to the wing mirror puts em straight..
98' Bandit 600 with Slip on
PostPosted: 20:57 - 19 Dec 2004    Post subject: Reply with quote
Under the trim around the inside of the fiaring there is the filler for the header tank (from memory).
Steve O
PostPosted: 21:52 - 19 Dec 2004    Post subject: Filler Reply with quote
Thanks for the replies lads, will look tomorrow in the light.
Regards Steve
PostPosted: 22:44 - 19 Dec 2004    Post subject: Reply with quote
Radiator cap is under the fairing on the left hand side, if you turn the bars all the way to the right and pull back the fairing a little, you can fiddle the cap off without having to dismantle anything. Similar story for the expansion bottle at the other side. A funnel is handy to get the coolant in without getting it all over the plastics.
Fill the radiator to the brim, top up the expansion bottle so it is between the marks, run for a short while then top-up again.
For future reference, the coolant drain plug is a small hex head set-screw in the bottom of the water pump housing at the front right of the engine.
Steve O
PostPosted: 00:10 - 21 Dec 2004    Post subject: Found It Reply with quote
Thanks for the replies you were all close. it was under a small cover in the right side of the fairing infill panel. It did need a small amount of antifreeze.
Thanks for the help
Steve
Regards Steve
PostPosted: 11:56 - 21 Dec 2004    Post subject: Reply with quote
Ah, it is the old model, pre '96. They had different plastics on them.
The last post was made 21 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 51.87 Kb
