gs125 1999 carb
manson
PostPosted: 13:01 - 04 Nov 2013    Post subject: gs125 1999 carb Reply with quote
can anyone tell me the amount of turns out the airscrew is please, its a mikuni cv carb. thanks
KymcoRatChop
PostPosted: 02:22 - 09 Nov 2013    Post subject: Re: gs125 1999 carb Reply with quote
You don't tell us anything about why you need the info - so I'm gonna assume you've messed with it;
Diagnosing the problem
Find which bit of the throttle the bike is not running properly at, this could be anything from dying when you first open the throttle to slightly bogging at 3/4 revs. The best way I have seen to do this is to make a mark on your throttle housing and a small mark on your grip level with it, open the throttle fully and make another mark on the housing, now split the space in between the marks into four equal sections with two more marks. Now you can see which part of the throttle you are at (by looking at the mark on the grip against the throttle) when the problems occur. Here are the corresponding throttle marks to the relevant parts of the carb.
Throttle Ranges:
Pilot Jet/air screw: idle - 1/4 throttle.
Needle Jet: 1/4 - 3/4 throttle
Main Jet: 3/4 - throttle fully open
Fixing the problem
Pilot Jet
Using the air screw you can determine if you have the correct pilot jet, screw in the air screw fully then out roughly one and a half turns to start. Start the engine, speed up the tick over until you get a slightly fast idle speed. Turn the air screw slowly in, and then out, until you find the point where the idle is fastest, stop there. If your air screw is less than one turn from fully closed you need a larger pilot jet, if it is more than 2.5 you need a smaller pilot. Once you have tried different jets (if applicable) and found the correct size then it time to set the mixture. Reset the tick over to a normal speed, ride around using only the first quarter throttle adjusting the mixture screw a small amount at a time either way until you get it running sweet.
Needle Jet
This is the most important setting at it is what you will be using most of the time. Ride the bike between the two middle marks on the throttle housing, if it bogs before responding to the throttle lower the clip on the carb slider needle a notch at a time until it picks up smoothly. If the bike splutters or sounds rough when picking up the revs raise the clip until it runs cleanly. You should be able to find a mid-point notch where the throttle responds nicely (if you cannot then complete the pilot jet setup even if you think the lower portion throttle is ok because this effects the needle jet).
Main Jet
This is where a plug chop is required. Install a new spark plug, find a long straight and warm up the bike. Set off and full throttle through the gears, when you reach top gear get to full throttle and hold it for 3-4 seconds before flicking the kill switch and pull in the clutch to roll to a stop. Now remove the spark plug and compare it to the “reading spark plugs” how-to guide. If you have a a lean mixture going up on the main jet size will fix it. A light brown or brown color indicates a perfect tune. If the mixture is rich a smaller main jet, clip adjustments, and air screw adjustments are needed. A little trick to double check your plug colour diagnosis is to turn on the choke slightly when the engine is running, if it runs better then you are to lean and if it runs worse then you either have the correct jet or a over size one.
You will notice that if you go through all of these steps and your main jet mixture is rich you are back to square one again! Therefore unless you have a carb that runs good apart from a particular part of the throttle range (so you can target that section to troubleshoot) you should follow the above guidelines in this order otherwise you can go round in circles.
main jet first
needle second
air and pilot last
Following the above simple steps should have your carb fully dialed in and result in a sweet running bike!
This is for tuning or setting up a new carb -without specs Smile Keep fiddling,but witha guide you may figure it out!
manson
PostPosted: 07:28 - 09 Nov 2013    Post subject: Reply with quote
FANTASTIC, SORRY WAS A BIT VAGUE BUT YOU HAVE GIVEN ME EXACTLEY WHAT I NEEDED, YOUR A STAR THANK YOU VERY MUCH.
KymcoRatChop
PostPosted: 16:01 - 09 Nov 2013    Post subject: Reply with quote
No problem mate Thumbs Up
The last post was made 12 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.72 - MySQL Queries: 15 - Page Size: 42.88 Kb
