| owl10 |
 owl10 Could Be A Chat Bot
 Posted: 18:30 - 09 Nov 2013 Post subject: ZX6R J1 Hard to start, cuts out on idle |
Hi All.
Got an issue with my ZX6R J1 (year 2000), All help welcome!
Bike has covered 30k miles.
Was fine until recently, I noticed a backfire on startup.
After this, no backfire but took 10 mins to start (was worried battery wasn't going to make it)
Now, still very hard to start, regardless of where choke is, tends only to want a tiny amount of choke.
Eventually it will start, if leaving throttle well alone, however idles rough and wont hold an idle.
Its ok when riding.
Don't know when plugs were last changed (ive had the bike 3 years / 12k )so will do them next weekend.
Will also cover carbs in carb cleaner (were balanced 3 yrs ago)
Given the backfire, im wondering if some seals have perhaps gone on the carbs, leaving extra fuel in there and stopping starting?
Any other suspects (coilpacks?)
Any help appreciated, cheers. ____________________ DanceLikeAMonkey says: "An infinte amount of web pages available
Yet I still end up reading crap like that" |
| G |
 G The Voice of Reason
| STONEY! |
 STONEY! Brolly Dolly
| G |
| Nobby the Bastard |
| owl10 |
| owl10 |
There is a gap of 298 days between these two posts... |
| austin460 |
 austin460 L Plate Warrior
 Posted: 13:23 - 04 Sep 2014 Post subject: |
Any further updates on this problem as my J1 has just started showing the same symptoms.
Any help greatly appreciated  |
| stevo as b4 |
 Posted: 17:23 - 04 Sep 2014 Post subject: |
My old J1 was from new a terrible hot starter. I think it's partly Kawasaki character like having the loudest 600cc airbox growl, the loosest rattly sounding engine, and a fairly vocal exhaust for a std can etc.
Was more than made up for by the silky smooth carburation, and useable drive from 2000rpm, along with a fit for the engine capacity midrange and no holes or flat spots CBR6 stylie!
I think they all suffer with fuel evaporation, and if parked when really hot, they always seem hard to start until it cools a fair bit. Mine used to backfire at times too, but cold starting was never as much of a problem.
Like you say they don't need much choke, and I used to knock mine off after 5-10sec and hold a fast 2000rpm idle for 20-30sec or until it would tickover with no throttle input.
If it's a bad cold starter, you may have dirt in the carbs, or blocked cold start jets etc. If the fuel is stale they seem a lot worse than normal too. Try a full tank of premium UL and maybe a fuel system cleaner as an experiment too if you like?
Mine would run fine on 95 or 98RON, but I tended to use 98RON Ultimate etc, as I wanted the best for it. |
| austin460 |
 Posted: 21:04 - 04 Sep 2014 Post subject: |
Thanks
Think Im gonna order myself some vacuum gauges and check the carb balance, Im sure its nothing serious, I changed the air filter a while back and have since been told the kawasaki ones which I used tend to come with too much oil on them and need drying off a bit before installing, I am also intending on changing the can at the end of the month so will probably have a right proper look at it then.
Thanks  |
| Nobby the Bastard |
| austin460 |
The last post was made 11 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
