 mikesaa309 Traffic Copper
 Posted: 13:42 - 10 Nov 2013 Post subject: |
Wear is measured in miles not years so your 40k miles is quite significant. I would look at buying a complete unit from a crashed low-mileage bike based on the mileage and the symptoms. ____________________ a.k.a 'Geri'
 SQL World Chat Champion
 Posted: 14:13 - 10 Nov 2013 Post subject: |
A bit of white sludge is not unusual. At this time of year moisture in the air will condense in the engine and land up getting trapped in the flame trap in the breather. Short journeys won't help (although you will likely get oil that looks like a white emulsion as well).
The oil control rings are normally further down the piston from the upper rings that are there to provide compression, so a check of compression isn't a 100% guide to know if the rings are worn. Worn valve stem oil seals will probably be most noticeable when accelerating after gently slowing with the throttle closed for a while.
