ZX7R reserve not working and strange whistling
Nope.
PostPosted: 21:23 - 10 Nov 2013    Post subject: ZX7R reserve not working and strange whistling Reply with quote
Hi all,
So first of all I have an issue with the reserve on my ZX7R. When I'm riding along and the bike starts spluttering, if I switch to reserve it continues spluttering and cuts out. After about 15 mins it will fire up and I can carry on. Now obviously something is not right here and the fuel isn't getting through for a while. Is this a common issue? I've heard about some reserve issues on these bikes, what can I do about it? Is it a case of stripping the tap down and just giving it a clean and maybe replacing the diaphragm or is it related to my second problem...
When I've been out for a ride and I stop the bike, there is a distinct whistling from the tank. I think this is pressure building up in the tank and escaping through the pressure release. Is it supposed to whistle? If not, where is it so I can clean it out?
It works fine otherwise, no problems with it when it's running with the fuel tap set to the standard position.
As always, advice is appreciated. Thumbs Up
PostPosted: 21:27 - 10 Nov 2013    Post subject: Reply with quote
Sounds like your tank breather is blocked?
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Nope.
PostPosted: 21:31 - 10 Nov 2013    Post subject: Reply with quote
That's what I thought, but I can't find it! I cleaned out the breather in the cap, I also took off the breather pipe at the bottom but I could blow through it quite freely so I'd guess at there being something inside causing the problem. Maybe I should blow some compressed air through it. Thinking
stickybackbob
PostPosted: 22:20 - 10 Nov 2013    Post subject: Reply with quote
Had a similar problem on my ZXR. Even with a full tank, could overtake something and it would splutter, then cut out. Ran fine on reserve. In my case, the fuel pipe from the tank to the tap was restricting flow. Replaced that pipe and it's been fine since.
Don't know if it's the same set up as your model though.
MartQ
PostPosted: 22:41 - 10 Nov 2013    Post subject: Reply with quote
Sounds like the labyrinth in the filler cap is blocked. Next time it happens, stop and open the petrol cap for a second or two, close it and see if it runs ok immediately after, if so, this will be the problem. You can sometimes clear them by removing the cap and giving it a good blast with an airline (if you can find one that hasn't been replaced by one of the fancy digital machines).
Fizzer Thou
PostPosted: 09:24 - 11 Nov 2013    Post subject: Reply with quote
If the bike runs okay normally then why would it be the tank breather?Surely it would happen all of the time if that was the case.
Have a look at the fuel tap and internal filter itself.It may well be that when the fuel level is low any sludge or dirt that is in the bottom of the tank is causing a reduction in fuel flow.
As for the sound from the cap,my Exup1000 does the same thing,but there is no problem.
Always have a 'Plan B'
Hugh Farking Cant
PostPosted: 09:36 - 11 Nov 2013    Post subject: Reply with quote
Zxr 750 owner here;
Zx7r has similar tank set up;
Check reserve filter inside tank.
Check that the reserve fuel line to the tap is not pinched or nipped.
The whistling cap is a trait of these models.
The breather pipe you refer to is actually the water drain from the filler cap recess. A metal pipe goes through the tank itself and is prone to fracture and may have been plugged if so. If you endeaver to clear it , be prepared for the tank to empty its contents .
Hugh Farking Cant
PostPosted: 09:37 - 11 Nov 2013    Post subject: Reply with quote
Zxr 750 owner here;
The last post was made 12 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 57.89 Kb
