Dilema
numark1
Scared of girls
PostPosted: 00:53 - 20 Dec 2004    Post subject: Dilema Reply with quote
For ages my battery has never charged, infact since i bought the bike. I have had various tests done and rectifiers and still the battery does not charge... My dad sugguested taking the 33bhp restrictors out to see if that would help. The reason for this is because i only do about 10-15 miles a day to college and back and he thinks that the bike is not generating enough power to charge the battery. Could this be a resolution??? Also the spark plugs were very dirty and he sugguested changing the HT Cables. Would any of this help?? As you can probably tell, we are not very mechanically minded Sad
Sparks!
Sir Tart-a-lot
PostPosted: 00:57 - 20 Dec 2004    Post subject: Reply with quote
10-15 miles a day might be the problem.. but it won't make any difference being 33 bhp or full power...
Kram
PostPosted: 01:00 - 20 Dec 2004    Post subject: Reply with quote
run the bike on idle, and run a voltmeter over the battery terminals. it should be aroun 14.4v, try running it at high revs, and see if the voltage changes. it should say 14.4v at all revs...
if it shows different numbers(lower) it might be the reg/rectifier has gone.
what bike is it?
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
Annabella
Like a person, only smaller
PostPosted: 01:02 - 20 Dec 2004    Post subject: Reply with quote
Either way, I think your Dad has a top idea there Thumbs Up
When you did the tests did you have the lights on or off? Maybe try riding without your lights on for the short journeys that you are making...
Avast! Pirates ahoy!
I did Cadwell! Very Happy
numark1
Scared of girls
PostPosted: 01:08 - 20 Dec 2004    Post subject: Reply with quote
The guy at Trail and Track tested it and it was idling at about 12.something. The thing is most of the time i ride my bike now is in the dark due to the sun going down at 4. This means my lights need to be on all the time. I am going to do some motorway miles tomorrow with headlights on to see what happens. The only problem is what do i do if the battery does go flat? I wouldn't be able to get home.
Bike is a GSXR400. GK73A
BTW i'm on my 3rd CDI unit,
4th Battery and 4th Rectifier. Shocked
Kram
PostPosted: 01:11 - 20 Dec 2004    Post subject: Reply with quote
i think your electrics are screwed Confused
may i suggest a professional to look at it, maybe a short somewhere?
instigator
PostPosted: 01:15 - 20 Dec 2004    Post subject: Reply with quote
I would have thought 10-15 miles would be enough? My daily commute is 5 miles, tehre and back. *gulp*
PostPosted: 01:54 - 20 Dec 2004    Post subject: Reply with quote
There's your problem then, your battery charges at 14v. 12v is the resting voltage of the battery.
Maybe worth checking the alternator windings too. A workshop manual should tell you how to do this.
True Blue
PostPosted: 10:10 - 20 Dec 2004    Post subject: Reply with quote
markcatate wrote:
The only problem is what do i do if the battery does go flat? I wouldn't be able to get home. Shocked
It should be all right once you start the bike, I would have thought, providing you don't switch it off.
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
PostPosted: 10:22 - 20 Dec 2004    Post subject: Reply with quote
That voltage is low. Might be OK at idle, so you really need to check it with the engine running and revving to 5000rpm+. Some charging systems will not charge at all at low revs (one car I used to have would not charge the battery at all until it had been revved over 3000rpm).
Also check the headlight bulbs. Most Japanese market bikes have quite pathetic headlight bulbs, and if someone has put larger wattage bulbs in place then this will greatly increase the load on the battery, same if you are using heated grips or if you have the radiator fan wired on constantly.
The restriction should not have any effect on the charging system.
The last post was made 21 years, 267 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.9 - MySQL Queries: 13 - Page Size: 67.72 Kb
