Chain Adjusting
Knisis
PostPosted: 14:51 - 20 Dec 2004    Post subject: Chain Adjusting Reply with quote
Hi, Not sure if I've got a prob or not, but anyway...
Over the weekend I was cleaning my bike and noticed the chain was very loose. About 3 inches of movement (middle at the bottom).
I adjusted the chain so I had about 1.5 inches of movement, rolled the bike back and forward, then found the chain was even tighter.
After several hours of adjusting, realised, that when I rolled the bike back and forward (in gear) the slack transfer's from the bottom to top and vise versa.
Question is, Is this normal?
Finglonga
PostPosted: 15:07 - 20 Dec 2004    Post subject: Reply with quote
Always adjust your chain at its tightest spot.
Rotate the wheel until the tightest spot is half way between front and rear sprockets on the bottom run. Adjust it to the recomended tightness, ....Job done.
It will not be the same as you rotate the wheel due to sprocket wear and the chain stretching. If its eccesive it might be worth getting a new chain and sprockets
Andy Sez....
F.Y.Y.F.F.
The last post was made 21 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.2 - MySQL Queries: 13 - Page Size: 31.5 Kb
