Rounded nut removal tool
bridgedino
PostPosted: 14:23 - 15 Nov 2013    Post subject: Rounded nut removal tool Reply with quote
https://www.ebay.co.uk/itm/390351171705?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D390351171705%26_rdc%3D1
Anyone had any experience of such a tool? The 8mm head on my front pads removal pin wouldn't budge and started to round so I stopped. Now I'm thinking I can use such a tool to finish of removing it and simply replace with a new one.
I'm trying to avoid paying a mechanic for what should be a 5 min job...now where have I heard that before
Anyone help
PostPosted: 14:25 - 15 Nov 2013    Post subject: Reply with quote
If it's tight enough to round the head with a good 6-sides socket, there's a good chance that you'll shear the head off with that tool.
Can you get some heat into it?
bridgedino
PostPosted: 14:29 - 15 Nov 2013    Post subject: Reply with quote
Not without buying something other than the OH hair dryer. I did wonder wether it would snap before freeing up. In which case the job would turn into more than just a rounded head
Raffles
PostPosted: 14:59 - 15 Nov 2013    Post subject: Reply with quote
As Pete said, heat will help. I also find that a decent smack with a suitable hammer helps to loosen tight fastenings.
bridgedino
PostPosted: 15:09 - 15 Nov 2013    Post subject: Reply with quote
Mole grips? Yep got them. Do they normaly perform well for such tasks?
Aff
PostPosted: 15:18 - 15 Nov 2013    Post subject: Reply with quote
If you can get one of those tools on, you should be able to file some flats on the head and use your mole grips.
Electric Bike Project
PostPosted: 16:34 - 15 Nov 2013    Post subject: Reply with quote
I love my Irwins. This is exactly what they're for, and if Irwins would shear the head off, so would mole grips. I have literally sweated and bled over a fastener in an awkward location for half an hour, filing and trying to get grips on it, before remembering that I've got Irwins, then squeeeak, off it comes.
Do give it a good whack and get some penetrating oil in there first though.
bridgedino
PostPosted: 16:48 - 15 Nov 2013    Post subject: Reply with quote
Irwin's ordered. Few days delivery time so will give it a good few squirts to help loosen before they arrive
Raffles
PostPosted: 17:23 - 15 Nov 2013    Post subject: Reply with quote
You did order the 'expansion set', didn't you?
sidewinder
PostPosted: 17:28 - 15 Nov 2013    Post subject: Reply with quote
Get yourself a nut splitter
https://www.ebay.co.uk/itm/Silverline-2-15mm-15-22mm-Nut-Splitter-Set-2pce-Threading-Mechanic-Tools-DIY-/350669056398?pt=UK_Hand_Tools_Equipment&hash=item51a581298e. Thumbs Up
sidewinder
PostPosted: 17:35 - 15 Nov 2013    Post subject: Reply with quote
sprintster
PostPosted: 19:00 - 16 Nov 2013    Post subject: Reply with quote
Draper Hi-Torq sockets are great for gripping rounded bolts.I was using them today to remove bolts under my mudguard that haven't been touched in 65k miles.There's no way a normal socket would have gripped them!A lot cheaper than Irwins too. Thumbs Up
bridgedino
PostPosted: 21:22 - 24 Nov 2013    Post subject: Reply with quote
Just used the Irwin's. They arrived earlier this week and I've just gotten round to the task. Perfect and hassle free removal of the bolt head that was starting to round off.
Get yourself a set
DMCpro
PostPosted: 21:45 - 24 Nov 2013    Post subject: Reply with quote
Links to where you got your Irwin's? Never seen them
Before normally I just use an array of screwdrivers chisels hammers and mole grips I always get em off but most of the time there's a lot of blood shed
Honda CB-1, TS125X
VW Golf Estate
Raffles
PostPosted: 22:12 - 24 Nov 2013    Post subject: Reply with quote
There's a link in the opening post.
Walloper
PostPosted: 02:12 - 25 Nov 2013    Post subject: Reply with quote
Get yourself a set
Away ya tight fisted Fifer ye. I'll just come up and borrow your now. Razz
heapy
PostPosted: 04:43 - 25 Nov 2013    Post subject: Reply with quote
https://www.youtube.com/watch?v=E90IH20he80
if it has 2 wheels and an engine its a bike
heapy
PostPosted: 04:44 - 25 Nov 2013    Post subject: Reply with quote
smegballs
PostPosted: 05:09 - 25 Nov 2013    Post subject: Reply with quote
Irwin "unfuckers" are really good, they've saved my bacon plenty of times.
They've got unstuck fasteners for me when a nothing in a £5k+ snap-on armory (my mates) has failed to do the job.
el_oso
PostPosted: 10:30 - 25 Nov 2013    Post subject: Reply with quote
sidewinder wrote:
how is a nut slitter going to work for pad retaining pins?
Depending on what calliper this is this may/may not work.
On the SV650 that is sitting on my drive the pins were stuck. very stuck. Took the calliper off and place in a vice and tried the mole grips and no such luck. I ended up drilling the other side of the pin out, only drilling through a few mm of ally and used a hammer and punch to push the pin out. Took all of 10 minutes and now have some callipers that are easy to work on. I'll try and get a picture.
https://cdn.bikechatforums.com/files/calliper.jpg
Duke 390
Car: Jeep Wrangler 4.0L
Rigga
PostPosted: 12:19 - 25 Nov 2013    Post subject: Reply with quote
He forgot the wd40!
Current bike: Honda CBR 1100xx
Rigga
PostPosted: 12:21 - 25 Nov 2013    Post subject: Reply with quote
He forgot the wd40!
Islander
PostPosted: 12:46 - 25 Nov 2013    Post subject: Reply with quote
Why would he want to use a water dispersant spray on it?
The last post was made 12 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 127.05 Kb
