cutting out???
daz|n00by
The Internet
PostPosted: 17:24 - 20 Dec 2004    Post subject: cutting out??? Reply with quote
hi guys aprillia 125 tureg model but rotax 123 engine (same as rs early rs i belive) ok the problem is this since the drop in temprature around my way both mine and my sons bikes have started cutting out at tick over even when warm, they tick over fine on choke until they start warming up then they tick over ok for just a short while after choke is off then they juust keep cutting out at tick over i,m wondering if this is a symptom of cold weather and nothing to worry about or should i adjuust the idle speed ? i dont mind adjusting the idle but could some body put me on the right screw to adjust please i dont want to mess the mix up as far as i can see the carbs look standard
thanks for any ideas in advance
daz
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
killergibbo
PostPosted: 03:22 - 21 Dec 2004    Post subject: Reply with quote
ie been havin this problem with my tzr50 it cuts out wen am ridin and it will not let me full trottle at all it just die's
but then i found out later cos i was sluggin it home fromwork like i mean goin 5mph lol cos it wud not pull after a bit it started lettin me full trottle and get the speed up just warm it up for along time and wen warmin it up hold the clutch in and rev it for a bit to heat the engine oil up
jamie192
PostPosted: 11:30 - 21 Dec 2004    Post subject: Reply with quote
you may be having the same problem as me with jets and ect ect, if the engine is smaller or bigger cc it might want a new jet or tuneing. The carbs are from your aprilia or are they from the rotax engine.
Ride Fast, Brake hard, don't fall off!
The last post was made 21 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.77 - MySQL Queries: 13 - Page Size: 35.37 Kb
