| blue175 |
 blue175 Derestricted Danger
 Posted: 01:11 - 18 Nov 2013 Post subject: Yamaha DT175; Smokes a ton and powerless |
I have recently bought a 1975 Yamaha dt 175 with around 2000 miles on it and It has some issues running.
It smokes alot of white smoke out of the exhaust, oil spatters out the the exhaust and it is practically powerless.
I have a fresh right side crank seal in and it does run better than it used to. I am running premix of about 1:32.
I don't know if this is related but the clutch doesn't fully dissengage and It has 5 drive gears and no neutral. I think they were supposed to have 4 drive gears....
I would really like to know what's wrong and how to fix it.
Thanks in advance,
Blue175 |
| hmmmnz |
 hmmmnz Super Spammer
| blue175 |
| nathan k |
 nathan k Spanner Monkey
| blue175 |
| nathan k |
| blue175 |
| dansp1 |
 dansp1 Nitrous Nuisance
 Posted: 08:08 - 18 Nov 2013 Post subject: |
Crank seals lunched, sucking gearbox oil into the crankcase, sounds like it has ep90 in the gearbox too  |
| iooi |
 iooi Super Spammer
| pdg |
 pdg World Chat Champion
| pdg |
 - Super Spammer
| blue175 |
| blue175 |
| bikenut |
 bikenut World Chat Champion
| blue175 |
 Posted: 16:17 - 18 Nov 2013 Post subject: |
I didn't know of the exploded views. I actuallly replaced the crank seal yesterday, and by o ring do you mean the actuall crank seal or the really small ring?
And yikes I forgot to cut the electircs to the oil pump
I adjusted the throttle cable needle and that made some difference with the smoke. I do think alot of it is burning out of the exhaust becuase when the exhaust heats up, even if I turn off the bike there is still some smoke trickling out.
Somthing else for you, The bike isn't powerless, it just cant get into the higher RPMs. The gauge reads 4000 as the highest it will go, and any lower than 2000 It will die. It just wont rev any higher and will not idle at all.
Oil litteraly drips from the exhaust. |
| stickybackbob |
 stickybackbob Trackday Trickster
 Posted: 16:43 - 18 Nov 2013 Post subject: |
As it's an old two stroke, it should be blowing blue smoke out of the back although not too much.
Before you mess about with any more carb settings, was there still oil in the lines/pump. If the engine is getting a double dose of oil, then it will be running very lean.
If it was meant to run with an oil pump, then it should be running one. Pre-mix is a 'get you home' job. Not sure on your particular bike but is there a pipe running from the oil pump to the carb? If so, this needs to be blanked off to run pre-mix as it'll be pulling extra oil or air in the mix.
If it's just a cable to sort out the pump, then splash out on a cable or at worst, one of those emergency repair cable kits.
As you appear to have done a fair amount of work, there could be any number of 'adjustments' that have been made during the re-build so we'll just have to try and eliminate them one by one  |
| m3-paul |
 m3-paul Spanner Monkey
 - Super Spammer
| blue175 |
| stickybackbob |
| blue175 |
 - Super Spammer
| blue175 |
 Posted: 21:24 - 18 Nov 2013 Post subject: |
Okay, I plugged the oil lines and am working on shutting off the pump.
It is lagging so bad its not even funny, The smoke is so thick you could see it from 2000 miles away and if I hold it at full throttle it chokes out and dies. Im really thinking about aborting the mission and maybe reselling. I would love to get it riding but I have no idea whats wrong.
Im feeling very discouraged...  |
| blue175 |
The last post was made 12 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
