building regs question
grant965
PostPosted: 00:21 - 19 Nov 2013    Post subject: building regs question Reply with quote
Hi all, at work they have a tap for the mopbucket upstairs and there is no drain for any spill or splashback. As a result if you spill any more than 500ml it drips through the electrics in the floor and damages the lights and the tills on the floor below. Now work have said if it happens again you have to fork out for any damage. Is there anything in building regs that they should have done to prevent this. Surely they cant have a water supply with nowhere for waste water to go other than to pour into the electrics.
Thanks, Grant
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
DrSnoosnoo
PostPosted: 09:43 - 19 Nov 2013    Post subject: Reply with quote
what an absolute stupid idea?! A tap without a drain. If it splashes, and it gets on something that's totally unfit for purpose and if they try to charge YOU for it, I'd tell them they need to find somewhere that is actually FFP. Weird!
Skudd
PostPosted: 10:13 - 19 Nov 2013    Post subject: Reply with quote
Refuse to use faulty equipment that could put you at risk.
angryjonny
PostPosted: 11:58 - 19 Nov 2013    Post subject: Reply with quote
If there isn't something in building-regs about it then it'll only be because they can't include statements and rules to cover absolutely anything that you would expect to be common sense, like don't build fireplaces out of cardboard or don't plumb the toilet so that it flushes into the header tank.
An indoor tap, upstairs, that simply pours water onto the floor is lunacy and I'd refuse to use it until a sink or basin is installed. Plumbing and drainage go hand in hand.
The management saying you have to pay for any damage is no different to saying "If you fall off this balcony we haven't put any railings on (but we're making you use), you'll have to pay for the cleanup of your own remains" - nonsense and it illustrates that they're clearly idiots.
Raffles
PostPosted: 12:22 - 19 Nov 2013    Post subject: Reply with quote
Have you considered exercising a little more care when using the tap?
angryjonny
PostPosted: 12:44 - 19 Nov 2013    Post subject: Reply with quote
In OP's position I'd be reluctant to expose myself (hur hur) to the financial risk of the washer going while I was using the tap. So I'd probably just not use it.
PostPosted: 12:55 - 19 Nov 2013    Post subject: Reply with quote
Workplace H&S enforcement authorities.
BakesBeans
PostPosted: 21:52 - 20 Nov 2013    Post subject: Reply with quote
It depends when the tap was installed. Building Regs only apply to new things built or installed. I.e. it could have been installed before building regs even existed.
What would apply is Health & Safety. And that is a big no no.
If they get difficult, ask to see their risk assessment of the tap!
Current: Kawasaki ZX636
Previous Bike: Honda CBR600F ABS, Yamaha XJ6 F Diversion ABS, Honda VFR400 NC30
sabian92
PostPosted: 22:17 - 20 Nov 2013    Post subject: Reply with quote
I fail to see when it was okay to install a tap without drainage above electrics... Laughing
Mark_F
PostPosted: 22:31 - 20 Nov 2013    Post subject: Reply with quote
To an extent it's done now all the time (in that bleed valves on pipework are often above lighting and cabling routes, and have no drain. They aren't exactly in daily use though unlike regular taps).
I doubt there's anything in the regs covering it if the affected electrical bits are not exposed (ie they are buried in a ceiling etc) There are notes on where electrical fixings should/should not be placed in regard to things like sinks etc in the electrical regulations, but electrical regulations are for guidance only (ie not legally binding). I suspect there are many parts of the building regs that aren't legally binding.
The last post was made 12 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 65.38 Kb
