Kawasaki GT550 G4 Starter Clutch Removal and Replacement
alansaxman
PostPosted: 20:40 - 17 Nov 2013    Post subject: Kawasaki GT550 G4 Starter Clutch Removal and Replacement Reply with quote
Hi, could anyone tell me if the starter clutch on a Kawasaki GT550 G4 can be replaced without removing the engine and splitting it, please?
Many thanks,
Alan
bikenut
PostPosted: 11:44 - 19 Nov 2013    Post subject: Reply with quote
starter clutch, if its the same as the gt750p5, then yes it can be done without removing or splitting the engine right down, its a bit involved however...........
from memory, exhausts and sump off.......clutch cover off, and i think the clutch basket has to come off also, then the shaft with the starter clucth and cush for primary drive chain............
you know of cmsnl for the exploded views??
the starter clutch is an FFFFFF expensive unit.........does your starter motor always spin and sometimes seems to catch and actually start the bike, then other times it just spinns with out rotating the engine??
how is your fuel tap, lets in fuel when its not supposed to, fills a cyl with pertol which then buggers the starter clutch ( and con rod etc )???
nuts about bikes
ssray
PostPosted: 12:20 - 19 Nov 2013    Post subject: Reply with quote
Yep its a pain,
I used to do this for myself and my dr mates, i wouldremove the exhaust turn the bike upside down and take the sump off
the only way then was to remove a layshaft(cant think which-long time ago)
the only other way is split the engine
Ray
bikenut
PostPosted: 15:21 - 19 Nov 2013    Post subject: Reply with quote
ps see cmnsl for the exploded views,,,,,they will help........ :karma:
nuts about bikes
The last post was made 12 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.83 - MySQL Queries: 13 - Page Size: 39.17 Kb
