| Dimonn |
 Dimonn Derestricted Danger
| J.M. |
 J.M. World Chat Champion
| Dimonn |
| Walloper |
 Walloper Super Spammer
 Posted: 13:58 - 19 Nov 2013 Post subject: |
The battery is recharged by the alternator at a certain engine RPM.
It normally doesn't charge much at idle and should begin charging at about 2000rpm.
The charging system is conrtolled by two things. A rectifier and a regulator.
The rectifier allows only + current produced by the alternator to flow to the battery. The - current is blocked and ignored.
Alternators are called alternators because the produce + and - current. So the current 'alternates' between + and -.
A generator will keep pumping out current at higher and higher levels until it reaches it's highest RPM or melts/explodes.
To be able to use the current produced at all RPMs a regulator is installed. This works like a relief valve and limits how much power goes to the system to charge. (A bit more complex than that).
If the alternator is not charging at your cruising speed then it may be that the regulator is not working properly and limiting the charge when the engine is 'off idle'.
Check the battery with the engine at idle and when the engine is lifted off idle. If the charge drops then it is the regulator.
A more worser thing could be the alternator is broken and so only make current at lower speeds. But I would check the regulator first.
There will be a forum electrician along soon I hope.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| DMCpro |
 DMCpro Traffic Copper
| jjdugen |
 jjdugen World Chat Champion
| Dimonn |
| Walloper |
| jjdugen |
 Posted: 15:33 - 19 Nov 2013 Post subject: |
Hi, yes, forgot to say tape up the switch so the operating plunger is pushed in, as it would be with the clutch lever fully out.
As this is the voltage line causing the problem, this would be my first thing to check.
Actually, (having another think), this switch carries twelve volts from the main loom, and, when 'made' as in the clutch out, it should be sending the twelve volts down the other lead to the ECU. Must be another interlock connected to this circuit, probably the neutral switch. I'll see if I can dig out a diagram for it and have a look. ____________________ The CBR900RR has been sold. Aprilia Falco worms its way into my heart.
Try Soi 23 on Amazon for a good read.... Self promotion? Moi? |
| Dimonn |
 Posted: 18:38 - 19 Nov 2013 Post subject: |
@Walloper you say its simple but i have been scratching my head at it for a month
I got delayed from university so its too dark to do anything today but i uploaded a video showing the lights dimming as i move the clutch lever out a little bit, sorry its dark but that's the only way you can see it: https://www.youtube.com/watch?v=Lv4QDw8J92k
Ill tape up the clutch switch tomorrow morning thanks for your help guys i actually never though of that |
| Dimonn |
| Walloper |
| Dimonn |
 Posted: 15:26 - 20 Nov 2013 Post subject: |
The real difficulty is that a lot of the stuff is not easy to identify or access.
[/quote]
You can say that again, i swear the wiring on an XJ is a lot tighter than on my old YBR where all the wires had enough slack to play with. Also a huge connector block is under the fuel tank
Also I removed the clutch switch and there isnt any voltage drop now so there is something shorting along that line, maybe a component that burned out when i miswired it, ill keep looking but does anyone have a good method how to test different components with a multimeter and tell which one it is?
For now ill just ride it with the clutch switch out until i solve the problem, again thank you, i actually never thought of doing that |
The last post was made 12 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
