| Spanner |
 Spanner Banned
| map |
 map Mr Calendar
 Posted: 16:52 - 19 Nov 2013 Post subject: |
Depends what you want it for.
I have a small Draper for the small stuff (eg brake mountings).
I have a larger one (from Argos iirc) for larger stuff (eg wheel nuts).
Both do the job they were made to do. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Spanner |
 Spanner Banned
| map |
 map Mr Calendar
| _Iain_ |
 _Iain_ Banned
| chris-red |
 Posted: 17:52 - 19 Nov 2013 Post subject: |
I feel I can't say 'The torque wrench made me do it' I should have know better. But 100% if I hadn't of used it I wouldn't have sheared that bolt.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| Spanner |
 Spanner Banned
 Posted: 08:38 - 20 Nov 2013 Post subject: |
| _Iain_ wrote: | Dont bother.
Unless you find yourself removing cylinder heads & conrods it's not worth it at all. Just tighten the bolts up by hand...this need to use a torque wrench for everything is nonsence - unless you get it recalibrated & store it correctly then it's not even going to be accurate anyway
See thread on clutch rebuild for example of torque wrench causing a bolt to snap that otherwise wouldn't have. Did clutch rebuild, diddnt use torque wrench, no kittens were killed, 10,000 miles later it's still going strong.
| chris-red wrote: | ...Now the little bit of fail, my draper torque wrench appears to be fucked, I set to to 10nm to do the bolts up and the second I thought this seems a bit tight the fecking head of one of the bolts sheered off. Luckily removing the bolt wasn't too much trouble.
https://img.photobucket.com/albums/v295/chris-red/IMG_0073_zps6dbea3dd.jpg
I replaced it temporarily with another bolt and washer but I have a new one on order. I also marked the bolts as as I had no torque wrench I had to guess, I'll have it open to replace the bolt in a few days so I can check them. When you tighten everything up do them all up part way and tighten them by choosing one then pick the opposite one and do another and the opposite etc. |
Well, things which require calibration in business, don't often go out of calibration, so I wouldn't say it's useless.
You'll most likely find, that there was a problem with the bolt, rather than the torque wrench. Sure, you may not have broken the bolt if you weren't giving it the torque, but you may have been left with an inferior bolt. There's a reason manufactures specify torque and without it, how can you be sure? |
| chris-red |
 Posted: 11:52 - 20 Nov 2013 Post subject: |
| Spanner wrote: | | _Iain_ wrote: | Dont bother.
Calibration I can understand, however an 18 month old torque wrench that has been used maybe 3-4 times should never be so un calibrated it snaps a bolt at 10nm.
It wasn't the bolt as I put a completely unrelated bolt in the vice set it to 10nm again and managed to snap it before the torque wrench clicked. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| Spanner |
 Spanner Banned
| Vincent |
 Vincent Banned
| barrkel |
 barrkel World Chat Champion
 Posted: 16:13 - 20 Nov 2013 Post subject: |
I have two, one 1/4", one 3/8". The upper range of the smaller one overlaps with the lower range of the bigger one. That means I can check if they're in the same ballpark with one another to WRT calibration.
Ideally I'd have a third wrench so I'd know which one is off if they were different. I'm also presuming that any calibration affects each end of the range at different rates, which ought to be a reasonable assumption from Hooke's law. ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Copycat73 |
 Copycat73 World Chat Champion
| cdzr |
 cdzr Derestricted Danger
| Copycat73 |
| cdzr |
| -Matt- |
 -Matt- World Chat Champion
 Posted: 03:13 - 21 Nov 2013 Post subject: |
Fairly amateur with the technical and mechanical stuff to pre-warn.
I've got two torque wrenches as i don't trust myself without them currently, which IIRC are,
1] 8nm-80nm from machinemart for 20 quid or so.
2] 80nm-210nm from argos again around 20 quid or so.
I've read the least accurate torques are at the top and bottom end of the range - may be total bollucks, feel free to confirm anyone , but on that basis i figured most of my bike torques were 15-50ish that i do for general basic maintainence - anything below that i just nip up with allen keys or whatever.
Realistically, the 80-210nm argos wrench i've never used on the bike - its come in handy for the car doing wheels and the like, but unless i get to a stage i feel comfortable disassembling the bike to a greater extent its more a reassurance having it in the box than something thats actually useful to me.
Also i wouldn't buy based on them being 1/2, 1/4 etc, if you get an adaptor kit you can interlink sockets/wrenches regardless. Can get them for peanuts on ebay, just make sure the extended length of the socket area doesn't make you start tightening at a slight angle  |
| Ichy |
 Ichy World Chat Champion
 Posted: 07:41 - 21 Nov 2013 Post subject: |
You can roughly test a torque wrench with a spring balance that reads in lbs, one of the cheap luggage scale ones is fine. Set the wrench to 10nm and put it on a bolt for testing, preferably one that is much higher than 10nm. Put the hook of the balance on the wrench handle about a foot from the bolt. Pull on the balance. One Nm is 0.737ft lb so the scales should read around 7.3lbs when the wrench clicks. Given a tolerance of 10% anywhere between 6.5 and 8 is fine.
BTW. I've tested a couple of the ones that sell in Aldi and Lidl. They are pretty good. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Walloper |
 Walloper Super Spammer
| Ichy |
| dydey90 |
 dydey90 World Chat Champion
| davebike |
 davebike World Chat Champion
 Posted: 10:20 - 21 Nov 2013 Post subject: |
There good for novices and for doing very critical jobs like cylinder heads I must say it is a busy week if I use mine but my bolt tightening head has had 5years of profession use =so is fairly well calibrated
Re calibration of cheap torque wrenches is uneconomic unless you find a friendly big workshop with a test set up I just replace if it think it iffy
I only use a 3/8 drive one most of the time if it need more than that will do I have a real big 1/2 job but hardly ever use it a bar and common sense is fine
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| map |
 map Mr Calendar
| Walloper |
 Posted: 10:51 - 21 Nov 2013 Post subject: |
| esullivan |
 esullivan Could Be A Chat Bot
 Posted: 10:56 - 21 Nov 2013 Post subject: |
The only place I use a torque wrench is on the main wheel nut, after adjusting my chain. I tighten with a decent (draper) socket wrench until I get the aforementioned two grunts and a groan, and then use this one: clicky and will get another bit of tightening (mostly because of the long handle, probably) before the click.
It's cheap (less than £45), but the wheel hasn't come off yet and I've used it several times. ____________________ Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
| _Iain_ |
 _Iain_ Banned
The last post was made 12 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
