Pinlock Visor Anti-Fog Stuff
Walloper
PostPosted: 09:42 - 21 Nov 2013    Post subject: Pinlock Visor Anti-Fog Stuff Reply with quote
My Pinlock got all hot and bothered yesterday morning in the cold and humid rush hour.
I knew the problem was the way I had fitted the insert to my new visor and that moisture had migrated under the silicone seal and was now condensing on the cold inside surface of the visor.
I punched Pinlock into my Internet terminal/Human Interface Device and got the Dutch company's web page with all stuff about fitting and fixing them.
No mystique.
https://www.pinlock.nl/motor/company/
Enjoy.
jeddy11
PostPosted: 11:16 - 21 Nov 2013    Post subject: Reply with quote
I would go as far to say probably 90% of pinlocks fogging up are down to fitting error..
And the other 10% need taking off and a good clean Razz
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
esullivan
PostPosted: 11:38 - 21 Nov 2013    Post subject: Reply with quote
On particularly cold and wet days, mine will develop a small patch of fog near my nose, then gradually creep up the side. It's not in front of me, but annoying when looking to the side at the mirrors or whatnot. This happens only when I'm moving slowly and goes away quickly if I pick up speed or flip up the visor for a few minutes.
Does this sound right or do I not have them installed correctly?
I'm always paranoid about bending (the usually brand new) visor when I'm putting the pinlock on. I probably don't flatten it enough. I've had a visor warp on me and that was very obviously not working. There was a visible gap between the pinlock and visor and even on slightly wet days the visor would fog right up.
Current: '14 VFR800X Test passed 31/10/12.
Previous: '12 NC700S, '11 CBF 125, '04 SH 125.
jeddy11
PostPosted: 11:47 - 21 Nov 2013    Post subject: Reply with quote
definitely needs to be sealed all the way round no gaps dirt even deep scratches will stop the seal.
I get a little thumb size mist right at the bottom other than that its really good.
Fuelly My Z1000SX
Method
PostPosted: 11:55 - 21 Nov 2013    Post subject: Reply with quote
The best thing to do with Pinlock's is to fit them - and never take them out.
They eventually become weak and dont seal how they should. The more you take them out and re-fit them, the faster this happens.
A new pinlock fitted correctly to a clean visor should last for a year without misting.
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Walloper
PostPosted: 12:17 - 21 Nov 2013    Post subject: Reply with quote
This too.
The thing with pinlock insert that lots don't know is that the insert is by design 'moisture absorbent'.
Sooooo... if you wet it and then fit it the surface will already be 'saturated' so the absorbent quality is negated and any moisture in the 'trapped' air between the visor and insert can condense on the visor.
So if you do get it wet, dry it or leave it somewhere dry before fitting.
This is what I have found over the years using them.
Dave70
PostPosted: 13:00 - 21 Nov 2013    Post subject: Reply with quote
Mine misted up a little around the edges for the first time yesterday. The weather was particularly bad though, with high winds and torrential rain.
Also, has anyone else had cracks develop on their visor around the pins? I have on my Shark lid, so it's not like its a cheap one.
MeatHelmet
PostPosted: 14:03 - 21 Nov 2013    Post subject: Reply with quote
The pins in the visor only allow you to fit the insert correctly one way.
They are contoured to accept the insert, so if you find your insert fogging up due to a poor seal, try turning the pins and make sure they are correctly aligned. Fixed mine in my old lid Thumbs Up
Bike - 2003 Kawasaki ZX6R 636 Ninja (A1P)
Shinigami
PostPosted: 14:48 - 21 Nov 2013    Post subject: Reply with quote
mines been fitted for well over a year and still no misting, absolutely swear by them
matto
PostPosted: 17:45 - 21 Nov 2013    Post subject: Reply with quote
Hmm... I recently bought a Shoei XR-1100 which came with a Pinlock thing that the guy in the shop fitted for me.
It's been rubbish, the first time I wore the helmet in the cold it started to mist and now a couple of weeks in it's got to the point that I was going to bin the insert and start using the visor spray stuff again.
However having read this thread it appears I'm in a minority so maybe if I clean and refit it then it might work properly?
Walloper
PostPosted: 18:56 - 21 Nov 2013    Post subject: Reply with quote
DO NOT USE ALCOHOL CLEANERS AS THEY FUCK UP THE COATING Sad
ADSrox0r
PostPosted: 21:18 - 21 Nov 2013    Post subject: Reply with quote
My pinlock has started misting a bit on the sort of days you would expect it to but tbh I just pop the visor up a couple of mm and let airflow do its thing. Meh.
dolly3900
PostPosted: 14:00 - 22 Nov 2013    Post subject: Reply with quote
YOU ABSOLUTE STAR MAN, LEGEND IN YOUR OWN LUNCHTIME.
I just thought my Pinlock had warped or something as it was not sitting correctly on my visor.
From the link you posted I see that I am being a total Beaker and had not set the pins on the visor correctly (did not know they were adjustable).
Result, no more fogging, no more cold nose, no more squinting.
Cheers matey, have a virtual pint on me Clapping
Mike
2002 Rieju RS2-50 (Sold, spares or repair), 2010 Suzuki DR-125SM (Traded for ->), 2007 Honda CBF 600 (Sold), 2010 Suzuki V-Strom 1000 (Briefly, now returned), 2007 Suzuki Intruder 1800m (Even More Briefly, traded in for ->), 2014 Suzuki V-Strom 650
Walloper
PostPosted: 16:08 - 22 Nov 2013    Post subject: Reply with quote
Mike
Thanks but virtual pints don't quench a man's thirst.
My Paypal account info for your pay-in.
[email protected]
Very Happy
The last post was made 12 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 88.48 Kb
