| Mario_Kempes |
 Mario_Kempes Trackday Trickster
| Nobby the Bastard |
| Fizzer Thou |
| Mario_Kempes |
| Nobby the Bastard |
 Posted: 23:04 - 21 Nov 2013 Post subject: |
| Fizzer Thou wrote: | | Nobby the chihuahua wrote: | If it has valve shims, I'd say that the valves are sticking open slightly, stopping it from running when cold, but as the engine warms up, the head expands more than the vlaves, opening up the clearances and aloowing it to run properly. |
Eh??
If the valve clearances are tight then as the engine warms up the gaps will reduce,not increase.
Perform a compression check first.If there is a low reading,drop some oil down each plug hole.If the reading stays low,the valve clearances should be checked. |
The head is made of a different metal to the valves. The head expands more than the valves, making the valves proproprtionally shorter.
It's a 'common' issue on FZs. The first time it happend, it took me about 4 months to work out what the problem was. All the valves were so tight that you couldn't get a feeler guage in there. Once re-shimed with thinner shims, the problem went away... ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
| davebike |
 davebike World Chat Champion
 Posted: 08:34 - 22 Nov 2013 Post subject: |
Probably just cold and flooded
But worth a good look over
Air filter and plugs
Plenty oil and not too old or dirty
Check there is coolant in the overflow tank
If all Ok then consider checking Valve clearances yes it has Shims
but not that lightly to be the problem
Dave ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
| c_dug |
 c_dug Super Spammer
| Nobby the Bastard |
| wilz1234 |
 wilz1234 Trackday Trickster
 Posted: 18:07 - 22 Nov 2013 Post subject: |
Probably just water or dirt in the tank, I too doubt that valve clearances would suddenly be a problem, then suddenly stop being a problem  ____________________ RS50 - ZXR400 - ZXR 400 - ZX7R - Bandit 600 - NTV 650 |
| Nobby the Bastard |
| Alpha-9 |
 Alpha-9 Super Spammer
| Nobby the Bastard |
| Alpha-9 |
 Posted: 19:03 - 22 Nov 2013 Post subject: |
Oh yeah, gaps will reduce, thus making less space
I am spacker brained
sounds like idle fuel mix balancing? ____________________ Fzr-600 1999 |
| Nobby the Bastard |
| temeluchus |
| Mario_Kempes |
| Mario_Kempes |
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:41 - 27 Nov 2013 Post subject: |
Never hurts to give the battery a good charge.
Unless it explodes, then it might hurt quite a bit. ____________________ Biking is 1/20th as dangerous as horse riding.
| Nobby the Bastard |
The last post was made 12 years, 84 days ago. Instead of replying here, would creating a new thread be more useful? |
