| map |
 map Mr Calendar
 Posted: 10:13 - 22 Nov 2013 Post subject: CB500 fuel problem |
Got a new to me 1994 CB500.
Riding to work the other week and fuel ran out.
Fair enough, I wasn't sure how much in before bought.
Put on reserve and went to petrol station.
Filled up, about £10 worth so say 8 litres give or take.
Reset odometer to check mileage when happened again.
Today it did, after about 90 miles
That's just wrong.
Filled up with 7 litres, say 1.5 imperial gallons.
A combination of Wikipedia and Haynes tells me tank capacity 18 litres and tank range about 196 miles.
So I'm thinking fuel tap blocked?
Just wanted to run it past others for a sanity check.
I guess internal tank could be damaged restricting capacity.
Other though was carb icing, but that does not explain starting on reserve straight away.
Any other input appreciated
P.S.
Working out consumption for 18 litre tank = 3.96 gallons for tank range 196 miles is about 49.5 mpg
So my 7 litres is about 1.5 gallons for 85 miles is about 56mpg. So that's right. So does this point to an issue with tank and fuel tap? ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| YBR Ric |
 YBR Ric Spanner Monkey
 Posted: 10:34 - 22 Nov 2013 Post subject: |
Fuel consuption seems OK for a 1994 model https://www.fuelly.com/motorcycle/honda/cb500
"So I'm thinking fuel tap blocked?
Just wanted to run it past others for a sanity check."
Yup, most likely the reserve outlet on the fuel tap is blocked. |
 Posted: 10:45 - 22 Nov 2013 Post subject: |
With the exception of a couple of other left of field suggestions I suspect you're right.
Might be that the vacuum has become detached or damaged so it's not opening the tap fully in which case it's cutting out when the head of perssure in the fuel isn't enough to force its way past.
Also consider the possability of a blocked tank breather.
Maybe have a look inside with a torch first to check the tank isn't totally mangled and 50% filler.
In any case, whipping the tank and fuel tap off and having a look should tell you what you need to know.
I usually take the whole tank off and lay it in an old tyre, tipped over far enough so the fuel has sloshed away from the tap. Quicker and easier than draining the tank and removing the tap in-situ and allows you to inspect the hoses properly too.Seems to work well with anything less than 2/3 full. Any fuller and you get fuel leaking out of the cap. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| davebike |
 davebike World Chat Champion
 Posted: 10:44 - 23 Nov 2013 Post subject: |
If you fill a CB500 on the side stand it will only get to about 3/4 full
If filling on the main stand and to proper full you may have lots of muck /water in the tank or major filled dents but but that would be unusual
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| pdg |
 pdg World Chat Champion
| Robby |
 Robby Dirty Old Man
| Vincent |
 Vincent Banned
The last post was made 12 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
