| Mattyboi |
 Mattyboi L Plate Warrior
 Posted: 21:20 - 21 Nov 2013 Post subject: Hello there, need help got a project |
I have a electrical fault with my speedo lights, i have replaced all bulbs as this bike is a project and needed some of them work (i think the other connectors need new ones) but basically all of the light stay on when the ignition is set to full or (engine on and lights on). So for example i put the ignition to the third position and all the speedo lights, light up including the oil, indicators, the full beam, the engine temp, the fuel light.
I know for a fact they shouldn't all light up when the ignition is all the way on. Now i will have a look tomorrow in the day light, but i don't fancy re-wiring the speedo light wires or having to strip them out and replace them, could this be a problem with some relay that shows the lights to be on when they need to, i.e the fuel when its low or the oil when its low.
When the ignition is at the second position though (engine on but not headlights) none of the lights show up even the indicators when i switch them on, there is nothing.
Now my oil is at its full, my fuel is full, my full beam is showing on even when full beam is on dipped and my engine would be cold but all the lights stay on.
Surely at least the indicator speedo light should flash when indicators are on but they just stay on, even when indicators are off. The only other thing i can think if is the brake switch is missing which im replacing next week after re-building the master cylinder i realised it had no brake switch, would this make the speedo lights short out or affect the connection?
Sorry for the vague crappy description of my problem but it all i could explain it as.
Thanks, Matt |
| davebike |
 davebike World Chat Champion
 Posted: 09:42 - 22 Nov 2013 Post subject: |
A clue like what bike make model year ???
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| c_dug |
 c_dug Super Spammer
 Posted: 09:46 - 22 Nov 2013 Post subject: |
In fairness that is better than the first attempt
As per the replies in the other thread check for a bad earth, any corroded looking joints or loose connections. ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Ichy |
 Ichy World Chat Champion
 Posted: 10:03 - 22 Nov 2013 Post subject: |
Is this with the bike running or just switched on? All of the circuits are remote to each other so it will not be one relay. If you let people know the make and model they can take a look at wiring diagrams to give an educated response.
My guess is that it is a Chinese moped. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| pdg |
 pdg World Chat Champion
| WD Forte |
 WD Forte World Chat Champion
The last post was made 12 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
