wiring a bike camera, help please
sut
PostPosted: 23:17 - 22 Nov 2013    Post subject: wiring a bike camera, help please Reply with quote
hi guys
i have brought my wife a lexmoto valencia 125. i have also brought a video recorder for the front of her bike to catch any muppet drivers hat show bikers no respect.
now my issue is my wife forgets everything so i cant have the camera wired to the battery as she will forget to turn it off and by the time she has finished work she will have a flat battery,
what i have brought is the camera https://www.ebay.co.uk/itm/151165037461?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 and the camer will take power from this https://www.ebay.co.uk/itm/390686451490?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
can you tell me what wires should i connect the cigarette lighter to so it is only live when the bike is running
thank you for any help.
DMCpro
PostPosted: 23:19 - 22 Nov 2013    Post subject: Reply with quote
Hi mate you will need to wire it to a relay and then you can wire it to your ignition can give a better explanation if you don't understand
Honda CB-1, TS125X
VW Golf Estate
sut
PostPosted: 23:33 - 22 Nov 2013    Post subject: Reply with quote
hi.
thank you for the reply, sorry to say i do not understand so if you can give more detail it would be great,
thank you
map
Mr Calendar
PostPosted: 23:50 - 22 Nov 2013    Post subject: Reply with quote
You wire a relay so you do not overload the bike's wiring.
A relay is an automatic switch. It turns on via a small current when you turn on the ignition. This switches the current directly to the attached device(s) (wired from bike's battery).
Stinkwheel on here did a definitive guide to wiring a relay into bike electrics. See here How to wire in an electrical device using a relay. (click on text link).
Hope this helps Thumbs Up
sut
PostPosted: 23:54 - 22 Nov 2013    Post subject: Reply with quote
thank you very much, great help.
map
Mr Calendar
PostPosted: 00:03 - 23 Nov 2013    Post subject: Reply with quote
For the camera you need to check
(a) it has auto start on power on
(b) it has record loop facility (so overwrites earliest footage when card full).
(c) power connections are waterproof (although silicon gunk may be your friend here).
There has been recent threads on cameras on here if you want to use the search (see top right of page).
The last post was made 12 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 49.17 Kb
