New CCM Adventure bike - 130kg claimed
Bike Chat Forums Index -> Biking News & Rumours Goto page 1, 2  Next
PostPosted: 21:34 - 24 Nov 2013    Post subject: New CCM Adventure bike - 130kg claimed Reply with quote
My CCM DRZ engine's big end went, but overall I did like the bike.
I thought it had a DRZ engine initially - it's actually a BMW engine, see below.
Does seem like a true 'adventure' bike, rather than a bit-taller-tourer as so many are.
https://www.ccm-motorcycles.com/_includes/images/banners/home/gp450/gp450.png
https://www.ccm-motorcycles.com/gp450.asp
I'd prefer a bigger engine, but if that weight is correct for the pictured bike (even dry rather than just no-fuel), that's pretty good and you'll be unlikely to match that with a circa-650cc engine I reckon.
Engine is apparently made by Kymco as used in the BMW 450, but detuned.
Some more (old) details. https://advrider.com/forums/showthread.php?t=857243
Drooling more, now - electric preload adjustment!
Not that'd I've got £8 never mind £8k to spend, but I do like the idea.
Sadly, it's not massively heavy with a BMW badge, so likely won't sell well Rolling Eyes.
Engine
Displacement
449.50ccm (27.43 cubic inches)
Engine Type
Single cylinder, Four-stroke
Engine Details
Titanium valves
Power
40.23 HP (29.4kw) @ 7000 RPM
Torque
42.80 Nm (31.6 ft.lbs) @ 6500 RPM
Top Speed
145.0 km/h (90 mph)
Compression
12.0:1
Bore x stroke
98.0 x 59.6 mm (3.9 x 2.3 inches)
Valves per cylinder
4
Fuel System
Injection. Electronic intake pipe/ keihin digital engine with overrun fuel cut-off.
Fuel Control
DOHC
Cooling System
Liquid
Gearbox
5-speed
Final Drive
Chain
Clutch
Multiple-disc, wet, Cable operated
Average Fuel consumption
4.50 litres/100 km (22.2 km/l or 52.27 mpg)
Emissions
104.4 CO2 g/km – Euro³
Service Intervals
8000km (5000 miles)
STATIC DIMENSIONS
Maximum Speed
145km/h
Dry Weight
130kg
Power/weight ratio
0.31 HP/kg
Seat Height
890mm
Overall Height
1,475 mm
Overall Length
2,170 mm
Wheelbase
1510 mm
Fuel Capacity
Approx 17.0 litres
Ground Clearance
360mm
CHASSIS, SUSPENSION, BRAKES & WHEELS
Frame Type
6082 T6 Forged Aluminium , machined finish, Lightweight Bonded
Rake (Fork Angle)
26.75°
Trail
108mm
Front Suspension
47mm Dia Upside Down forks, Rebound damping 18 stages, compression 12 stages
Rear Suspension
Cast Aluminium swingarm & linkage system, shock absorber with Pre load adjustment, 12 damping stages, 24 compression stages.
Front Wheel / Tyre
21” 90/90-21 54S TT Dunlop Trailmax
Rear Wheel / Tyre
18” 120/90-18 65T TT Dunlop Trailmax
Front Brake
Brembo Caliper, 320mm Disc
Rear Brake
Brembo Caliper, 240mm Disc
EQUIPMENT
Optional Equipment Storage Type
Left and Right hand lockable panniers
Storage Capacity
Hard and Soft Luggage
Lighting
Additional front Spot Light.
Maintenance
On-board vehicle specific toolkit & puncture repair kit
Optional Camera
Front facing HD Video Recorder with Storage & USB
Tractive Electronic Suspension
Adjustable Preload - on the move
Seat
Tall Seat option
Gear Ratios
Optional Sprockets
Nope.
PostPosted: 22:06 - 24 Nov 2013    Post subject: Reply with quote
Hmm, was tempted to go and look until I saw that there is ONE UK dealer. And it's in Bolton.
Great marketing channels and support network Rolling Eyes
PostPosted: 22:18 - 24 Nov 2013    Post subject: Reply with quote
One of the useful things with CCMs is they tend to buy in the majority of bits from recognised manufacturers.
While I had a problem with my Acumen speedo on the CCM, when I popped down to Acumen for them to have a look, they were incredibly helpful and dedicated a couple of hours to trying to fix my broken speed, despite it being well out of any warranty etc.
(Ok, you won't get the same service from WP etc, I expect - but at least parts are available.)
Vracktal
PostPosted: 23:23 - 24 Nov 2013    Post subject: Reply with quote
https://www.ccm-motorcycles.com/_includes/images/galleries/home/01.jpg
Interesting concept, looks like they forgot to bolt a fuel tank on though.
Understand they probably fitted a tiny one to lower the wet weight, but still, range is key on a bike touted as a globetrotter.
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
drzsta
PostPosted: 23:33 - 24 Nov 2013    Post subject: Reply with quote
17 litres is ample stock storage for this bike IMO.
PostPosted: 23:42 - 24 Nov 2013    Post subject: Reply with quote
Yea; while it's not so 'adventure' (bet they plan to offer bigger), 17l is probably at least 50% more usable capacity than your average dirt bike.
DrSnoosnoo
PostPosted: 11:28 - 25 Nov 2013    Post subject: Reply with quote
I actually like that. If I finish this PhD and get some money, I'll probably buy one ... if they're still around!
garth
PostPosted: 11:36 - 25 Nov 2013    Post subject: Reply with quote
I want that in my life
dydey90
PostPosted: 17:37 - 25 Nov 2013    Post subject: Reply with quote
It looks like they designed the front fairing by getting a shovel and going "Look at that gorgeous shape. Lets make this transparent and bolt it on the front"
PostPosted: 18:34 - 25 Nov 2013    Post subject: Reply with quote
You won't be able to see the shape when it's covered in South-American mud Smile.
PostPosted: 18:44 - 25 Nov 2013    Post subject: Reply with quote
I'd prefer it if they'd routed the exhaust header differently. Could it get bashed? The seat looks a little thin for all day riding.
Would that silencer hinder any luggage?
PostPosted: 19:06 - 25 Nov 2013    Post subject: Reply with quote
That's the standard routing for a dirt bike. Rally/adventure bikes often have it routed underneath the bike, to avoid bigger fuel tanks I presume - seemed to cause more problems if anything.
2 stroke bikes tend to suffer from this and end up looking more like golf balls, but trimmer 4 stroke exhausts (which can also use stiffer metal due to the smaller diameter meaning weight is less of an issue) generally seem to be ok.
The seat looks pretty darn comfortable for a dirt bike Smile.
They've presumably kept it low for the shorter of stature. My KTM one was massively less comfortable as standard. I had it modified with extra gel inserts which made it taller. Ok when loaded up, but when not I'd be on one tip-toe pretty much!
There's lots of pictures of luggage on the bike soft and hard with racks available from CCM to fit. Exhaust position looks fairly similar to the 690, bar that having the petrol tank on the right and exhaust on the left.
ScaredyCat
PostPosted: 19:32 - 25 Nov 2013    Post subject: Re: New CCM Adventure bike - 130kg claimed Reply with quote
G wrote:
Holy crap that thing's been beaten with the ugly stick, I presume they supply a lifetime of mirrors so that every time it catches itself in them you don't need to pay for new ones.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 20:00 - 25 Nov 2013    Post subject: Re: New CCM Adventure bike - 130kg claimed Reply with quote
It's just to put off all the Ewan and Thingy riders that buy bikes purely for the perception!
Again, not many mirrors in the South American Rain Forest to worry about.
But yes, it's not an ideal bike for Croydon high street!
Irn-Bru
PostPosted: 20:10 - 25 Nov 2013    Post subject: Reply with quote
Looks cool but I'd prefer this:
https://i.imgur.com/k1Sa8Uu.jpg
PostPosted: 20:31 - 25 Nov 2013    Post subject: Reply with quote
If the CCM weight is to be believed, it's possibly around 20kg down on the KTM; for a dirt focus, that's probably better.
Top speed is certainly down at a claimed 90mph (I've hit 108mph on the GPS with luggage and a pillion on the KTM), so won't be so relaxed on the road.
On that, I still want a wider ratio gear box for my KTM so I can have an overdrive-top gear (ie geared for 125-130) without losing too much in first.
Irn-Bru
PostPosted: 20:41 - 25 Nov 2013    Post subject: Reply with quote
I remember on my 690 SMC it got to around 100 in fifth and on to an indicated 120 in 6th on standard gearing. My DRZ mate was always confused I still had an extra gear left as I overtook his DRZ going flat out in 5th (95 - 100 eventually). The bike was not struggling at all but I was with the wind. I have seen much more pimped out 690's for Dakar sort of stuff but I couldn't find the pics, the ones with panniers and extra fuel tanks etc.
I do love these rally styled enduro bikes, they are cool! My KLE is like one that eats pies all day and never takes care of itself. 50hp 180kg Very Happy
yen_powell
PostPosted: 21:34 - 25 Nov 2013    Post subject: Reply with quote
https://www.xrv.org.uk/forums/attachments/africa-twin/38017d1385368435-bike-show-new-africa-twin-image.jpg
This may be the new Africa Twin. No more V-twin it seems.
XT1200Z and a DR350 in bits
Dischord
PostPosted: 21:25 - 04 Jan 2014    Post subject: Reply with quote
The last thing I would ever do is go touring abroad on a KTM 690 the electrics are a time bomb and would more than likely leave you stranded in the middle of nowhere in Romania or something Shocked
That CCM looks good but 40hp? Thumbs Down
2012 KTM EXC 250
Irn-Bru
PostPosted: 21:33 - 04 Jan 2014    Post subject: Reply with quote
You not have much luck with yours? Mine had electrical issues as well, FI light would come on and bike would go into limp mode. The FI in general was a bit iffy, the bike never really liked sitting at a constant speed and the throttle lacked feel, because well it's just a sensor talking to a computer which decides if your input is acceptable or not.
c-m
PostPosted: 18:03 - 05 Jan 2014    Post subject: Reply with quote
That is sexy. I bet they can't make it weigh less than 200kg wet though. Who's is it?
There's been loads of talk on the CCM 450GP on ADVrider. I like the idea that you plug in the power plug to get the full 54bhp. Of course it voids the warranty though, but it's a nice touch.
Whilst doing my Christmas shopping I noticed an article on it one of the usual magazines.
There's a link to the article at bottom of my blog post.
https://defylife.co.uk/adventure/bikes/perfect-adventure-bike-made-britain/
PostPosted: 18:38 - 05 Jan 2014    Post subject: Reply with quote
Interesting on the 'power plug'; makes sense as it's from a competition engine.
Next; can CCM do one with a TE610 engine? Seems the ideal choice with decent gear ratios (1:3.4 overall between bottom and top), a wide enough range of power and so on.
PostPosted: 20:18 - 05 Jan 2014    Post subject: Reply with quote
The 12 month warranty with mystery terms that just link to a sales brochure?
Small UK business? I'd expect it would be along the lines of "Sorry to hear that, mate, Dave Paperwork's in Magaluf but I'll ask him to get back to you two weeks on Tuesday, most likely, see if we can book you in to our workshop sometime in May or June, July at the latest. Or August. Our one workshop. In Bolton."
PostPosted: 20:23 - 05 Jan 2014    Post subject: Reply with quote
I'd be more worried it'll be a case of "nah, we've gone bust twice since then", but if you run out of bog paper....
Nope.
PostPosted: 23:48 - 05 Jan 2014    Post subject: Reply with quote
Having spoken to the thoroughly nice chap at the NEC I can confirm that they are in fact expanding their dealer network. The bike seems quite nice and from a glance it also seems well built. They have some nice bolt on features too.
For the money? Hell no. I'd buy something else until it's reliability is proven, but it might be worth a punt for somebody.
The last post was made 12 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 132.86 Kb
