| RideLimousin |
 RideLimousin Scooby Slapper
 Posted: 22:51 - 25 Nov 2013 Post subject: Karcher leaking oil and water :( |
My Karcher K2 series is out of warranty and leaks oil and water. I think the water leaking issue is probably something simple like changing out an elbow joint. However it also leaks oil so is only a matter of time before it goes pop if I can't resolve this.
Has anyone experienced a similair issue with a K2 or similair Karcher and is it worth trying to locate and fix the oil leak?
Cheers. ____________________ Motorcycle Touring Holidays in France: Ridelimousin
See my ridelimousin renovation blog: https://ridelimousin.blogspot.fr
See my renovation thread: https://www.bikechatforums.com/viewtopic.php?t=244340 |
| doggone |
 doggone World Chat Champion
| RideLimousin |
| bladerunner |
 bladerunner World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 00:29 - 26 Nov 2013 Post subject: |
Leaking oil and water can mean it's been frozen. ____________________ a.k.a 'Geri'
| Ariel Badger |
 Ariel Badger Super Spammer
| G |
 G The Voice of Reason
| Vincent |
 Vincent Banned
 Posted: 15:37 - 26 Nov 2013 Post subject: |
You seem to see a hell of a lot of bust Karchers on eBay so I'm guessing they're not very good. It's mainly the chepaer models but still.....
I picked up a Nilfisk one that was listed localy on eBay as "leaking water". 'Only had to replace a couple of seals and modify the pressure switch and ended up with a fully operational 99p pressure washer  ____________________ Space Is Deep |
| bikersupermot... |
 bikersupermot... Could Be A Chat Bot
| RideLimousin |
| Pete. |
 Pete. Super Spammer
| Marmalade |
 Marmalade World Chat Champion
 Posted: 11:45 - 27 Nov 2013 Post subject: |
| Vincent wrote: | You seem to see a hell of a lot of bust Karchers on eBay so I'm guessing they're not very good. It's mainly the chepaer models but still.....
I picked up a Nilfisk one that was listed localy on eBay as "leaking water". 'Only had to replace a couple of seals and modify the pressure switch and ended up with a fully operational 99p pressure washer  |
They are fine but people don't care for them.
If they leak then the head is cracked, same for it pulsing when on standby.
People leave water in them which freezes, causing the head to crack or the very few metal bits in there rust after being sat in water for 3 months since it was last used and causes expansion or the pressure releif to seize, drag them around by the pressure hose, causing the head to crack or knocking them into things or dumping them in the shed with pressure on the outlet, again causing it to crack.
Molded plastic units don't spontaneously crack when left in a shed in suitable conditions, something causes it.
I have a load here as i repair them if i ever get the time but have one main one i have used for years, always empty the water, sometimes spray a little wd40 in there but otherwise left to freeze in an old unheated shed.
Anyone near salisbury need a cheap one, working, get in touch ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
The last post was made 12 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
