FZR 600R GENESIS CLUTCH
aaronneary
PostPosted: 18:53 - 25 Nov 2013    Post subject: FZR 600R GENESIS CLUTCH Reply with quote
Hi, Was coming off the motorway and the clutch on my bike completely failed. Got the bike home took it apart and realised the push rod was broken. Made a new rod at work and reassembled. But there is still no tension on the clutch at all. Tried adjustment and at a complete loss. Can anyone put me on the right track. Thanks
FZR 600 R GENESIS(commute) - ZZR600 (nice weather)
base
PostPosted: 19:48 - 25 Nov 2013    Post subject: Reply with quote
Have you had adjuster sprocket cover off? as really there is not much to go wrong with them, how did the push rod fail any pictures, might help understand the cause of the problem a bit better.
I know the cable takes a tight route, I assume thats intact, is the new push rod long enough?
aaronneary
PostPosted: 20:16 - 25 Nov 2013    Post subject: Reply with quote
The cable is intact as it still operates the mechanism that would move the push rod. I made the rod at work today and made it to the exact size of the one that i removed. Don't know if that helps.
base
PostPosted: 22:54 - 25 Nov 2013    Post subject: Reply with quote
you say you made a new rod does it incorporate the ball bearing, that sits onto the pressure plate end,
Here is a link it may be of some help?? there is loads of fzr600 info.
https://www.fzrarchives.com/ipb/index.php?showtopic=56357
its such a simple set up rod, ball bearing short push rod onto pressure plate, if memory servers me correct.
base
PostPosted: 23:00 - 25 Nov 2013    Post subject: Reply with quote
here is a diagram of the set up
https://images.cmsnl.com/img/partslists/clutch_bigyau0029c-8_fa94.gif
69chris
PostPosted: 17:20 - 26 Nov 2013    Post subject: Reply with quote
never having one break myself id be wondering what caused the push rod to break in the 1st place Confused
when you say the clutch failed completely do you mean you had no drive or that the c/lever simply didnt do anything ?? Smile
base
PostPosted: 17:56 - 26 Nov 2013    Post subject: Reply with quote
If adjusted up too much they end up turning with the engine and this can apparently cause them to fail, so I have read, on a FZR forum.
PostPosted: 18:15 - 26 Nov 2013    Post subject: Reply with quote
Ignore me.
69chris
PostPosted: 18:38 - 26 Nov 2013    Post subject: Reply with quote
If adjusted up too much they end up turning with the engine and this can apparently cause them to fail, so I have read, on a FZR forum.[/quote]
yep i can sort of agree with that, well, i can agree that might 'burr' the ends of the p/rod,
but that would surely assume that the b/bearing was missing and the clutch was adjusted so tight that it must have been slipping at some point Confused
have had loads of old Z's that have the same set up and never had a problem with pushrods breaking, had the 'worm' lifter fail, had the clutch basket nut come undone and the clutch try to eat its way out through the cover, just never broke the p/rod Laughing
The last post was made 12 years, 326 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 62.47 Kb
