Kawasaki zx6r 1997 fork rebuild
BikeNewbie
PostPosted: 05:00 - 26 Nov 2013    Post subject: Kawasaki zx6r 1997 fork rebuild Reply with quote
Hi,
I need the seals changing which I know means the forks have to be taken apart, correct?
I don't have the tools for this job, so how much am I looking at for it to get done?
2 hour job?
Thanks.
andym
PostPosted: 05:43 - 26 Nov 2013    Post subject: Reply with quote
I'm sure almost everyone on here will disagree with me.... but I'll go ahead and say it anyway.
Unless you have a problem with the forks that require them to be completely stripped and rebuilt there is no need to go to all the effort of stripping them down.
I have done (to date), intruder 125, diversion 600, gpz 750, zxr 750 fork seals, and not once have I needed to strip the forks down.
Just drop the forks, remove the dust seals, use a screw driver to pop the old seals out then use them on top of the new seals to tap them into place... top up your fork oil, slap it all back together and you're good to go.... OK it's slightly more complex than that... but not much
This was the tools I used:
https://img.photobucket.com/albums/v320/andy36586/forksealtools_zps2e4d6c12.jpg
and this was after about half an hour:
https://img.photobucket.com/albums/v320/andy36586/forksremoved_zps635ade0e.jpg
PostPosted: 12:18 - 26 Nov 2013    Post subject: Re: Kawasaki zx6r 1997 fork rebuild Reply with quote
If you can get them out that way, using a screw driver can have a serious risk of damaging the chrome on the fork, which it is VERY important not to damage.
If you can do it without damaging it, fair play.
However, seeing that most forks only need two tools to get the seals off (maybe three), it may not be such an issue for the OP to do.
Allen key for the bottom bolt and socket/spanner for the top.
I'd expect a mechanic should have them done in an hour or less if you take the forks in to them.
andym
PostPosted: 13:28 - 26 Nov 2013    Post subject: Re: Kawasaki zx6r 1997 fork rebuild Reply with quote
I've always gone for the middle of the seal so never really worried about hitting the chrome and even though I use a hammer, that's just to make it easier to get through the rubber, it's more a couple of light taps I give the screwdriver
The last post was made 12 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 46.16 Kb
