Steering stem offsets
koolio
PostPosted: 12:40 - 26 Nov 2013    Post subject: Steering stem offsets Reply with quote
I know a little about rake and trail etc. am I right in assuming the less steering stem offset you have the more stable the bike is? Therefore offroad bikes have lots of steering stem offset and sports bikes have a small steering stem offset?
For example I note the Fireblade has very little steering stem offset.
https://img.auctiva.com/imgdata/3/3/6/4/3/2/webimg/627269898_o.jpg?nc=365
PostPosted: 13:22 - 26 Nov 2013    Post subject: Re: Steering stem offsets Reply with quote
Here's a CCM yoke to fit WP forks (well, actually it's been machined to fit a C90 Smile )
https://dl.dropboxusercontent.com/u/18968307/pics/c90ccm/2.JPG
Not too different.
However, what you will find is that the wheel is located forward of the centre of the forks there, while on a similar supermoto version it's often mounted in line (that's the case with the 690 enduro and SMC, that otherwise are very similar.)
https://www.yamaha-motor.eu/designcafe/en/about-design/technology/index.aspx?view=article&id=442629&page=2
kestrel
PostPosted: 22:46 - 26 Nov 2013    Post subject: Reply with quote
You can't judge a bike's stability by looking at fork offset alone, you have to examine the front end geometry as a whole, particularly the rake angle.
Reducing fork offset increases trail which gives greater straight line stability but slower steering. Reducing the rake angle will decrease the trail, giving quicker steering at the cost of straight line stability, it's very much a trade off.
As you can see, rake angle and fork offset changes both affect the trail value and ultimately the handling characteristics of the bike.
Wheel spindle position relative to the fork leg centreline also affects trail, which is why you often see bikes with the axle in front of or behind the forks.
Sketch a few front ends out with different offsets and rake angles, project the steering stem axis and drop perpendiculars from the wheel spindles and see how varying either value affects the trail.
Isle of Man.........Road Racing Capital Of The World
koolio
PostPosted: 21:39 - 28 Nov 2013    Post subject: Reply with quote
Yea I get it now, for some reason I thought that having a larger offset increases trail, clearly the opposite.
The last post was made 12 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 39.91 Kb
