Gilera Runner 50cc problem
Bl1nk
PostPosted: 09:47 - 27 Nov 2013    Post subject: Gilera Runner 50cc problem Reply with quote
Hy guys,
I'm a new biker and also new around here.
I have a problem with my gilera runner 50 cc (from 1998).
In the mornings/late night when it's pretty cold I can't start it... The electric ignition doesn't even try to start, no sound what so ever, and the kicker doesn't always work. For example, today I was around 15 mins on the kicker and couldn't start it...
Is it normal to have this much trouble to start when it's cold? (Around 6ÂșC)
Thank you guys
PostPosted: 10:57 - 27 Nov 2013    Post subject: Reply with quote
Sight unseen, I'd suspect that your battery isn't holding a charge.
#1 Do any of the electrics work with the engine not running?
#2 Have you tested it with a volt/multimeter?
#3 Have you put it on a charger?
#4 Have you checked and topped up the electrolyte levels in the cells?
Bl1nk
PostPosted: 11:27 - 27 Nov 2013    Post subject: Reply with quote
yes they work fine. the problem only appears when the bike is cold...
PostPosted: 11:57 - 27 Nov 2013    Post subject: Reply with quote
I'll assume that's:
#1 Yes
#2 No
#3 No
#4 No
Can you guess what you should do next?
Bl1nk
PostPosted: 12:01 - 27 Nov 2013    Post subject: Reply with quote
do n2 then 3 and 4 lol
tks
Bl1nk
PostPosted: 14:01 - 27 Nov 2013    Post subject: Reply with quote
laughting out loud = lol
thanks = tks
by the way, won't* Wink
bikersupermot...
PostPosted: 16:48 - 27 Nov 2013    Post subject: Reply with quote
its okies bl1nk
i understand ya haha
replace ur spark plug. take battery out and put it on a charger in ur house/flat overnight
make sure u got a tank full of fresh petrol
try again with above and see how you get on.
cold weather makes the engine harder for the starter motor to turn. it can also make it harder for the fuel mixture to ignite inside the engine making it harder to get it started.
you need a good strong battery - if u got access to electric where the scooter is parked id recommend u get a battery maintenance type charger like an optimate to keep your battery at peak performance.
tinybikes
PostPosted: 17:17 - 27 Nov 2013    Post subject: Reply with quote
I agree with checking the condition of the spark plug, but how would a fouled plug stop the starter from spinning the engine?
Randomly replacing bits is an expensive alternative to diagnosing the problem.
The last post was made 12 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 60.42 Kb
