Stupid newbie questions
neilthewolf
PostPosted: 19:19 - 29 Nov 2013    Post subject: Stupid newbie questions Reply with quote
Hi, passed my mod 2 a few weeks ago and I'm picking up my 02 vfr tomorrow. Not worried about size /weight of bike, have had test rides and it fits perfect. The problems that are going through my head are really stupid questions that your not given any info on while your training. Here goes....
1...when you go into a pay and display car park on your bike how can you display your ticket without someone coming and stealing it?
2...How often and how thorough do i clean my bike after say riding dry weekends through the winter, does the salt need washing off after every ride?
3...This is a daft one....when i maneuver into and out of my garage which is safest to start with...sitting on the bike and doing a million point turn to turn around or reverse backward or do i do the mod 1 exercise and walk my bike around? I'm 5ft10' and 200lbs and pretty strong.
4...The last question you'll be pleased to hear...are there any essentials i should be buying other than the obvious, i read a lot about how people have trouble with batteries on bikes should i buy a top battery or a battery charger? Whats the score with batteries on bikes?
Right that's all i can think of for now, if you can stop laughing at my stupidness I'd love some help.
Thanks
Neil
c_dug
PostPosted: 19:31 - 29 Nov 2013    Post subject: Re: Stupid newbie questions Reply with quote
They are far from stupid questions!
1) One of the perks of riding a motorcycle is free parking almost anywhere, check the signs but you will find in most places you just scoot around the barriers and don't have to pay.
2) I rarely clean my bike because I use it every day to commute on, it's kind of a piece of string question. There are lots of general maintenance bits that are far more important than shiny plastics, plenty of threads already on that so have a search and ask for specifics where needed Thumbs Up
3) It depends on a few things and you will work out what works best for you, for instance if there is a slope into and out of your garage it may be easiest to turn it around in the garage, you could use a turntable designed for the purpose or learn to rotate it on the sidestand.
4) I would suggest a basic tool kit if you don't already have one, motorcycles tend to be more hands on than cars so you may find in 6 months time you want to start doing your own brakes and oil changes. You will also want a chain lube of some sort and a big enough socket to fit your axel nut.
4b) You might want to consider some bits to stick under your seat for emergencies, things like a high vis vest and some spare bulbs.
PostPosted: 20:26 - 29 Nov 2013    Post subject: Re: Stupid newbie questions Reply with quote
1. I've never paid to park a motorcycle anywhere, and am yet to receive a speculative invoice.
2. Clean your bike and give it a thorough dose of ACF-50 - and I'd only recommend ACF-50, not a cheaper alternative. Wash it again in the spring.
3. Really depends on you. I'd walk it around. If you trust your side-stand, you can even spin the bike on it. This wins you 10 Man Points.
4. The used bikes that I've bought (bar Ze Beemer) have all come with a neglected, partially discharged battery with inadequate electrolyte. If you've got a lead-acid battery, check and top up the electrolyte levels, give it a good charge when you get it, then ride it regularly.
I would always recommend putting the battery on charge before trying to diagnose any problems on a vehicle, having had a laundry list of problems on my Citroen C3 from sad batteries.
If you only buy one tool, I'd suggest that it's a £5 multimeter. It takes so much of the guesswork out of diagnosing problems.
sidewinder
PostPosted: 21:53 - 29 Nov 2013    Post subject: Reply with quote
I would suggest you walk the bike in as it's good to get to know how your bike manoeuvres in tight spaces etc Thumbs Up
mic
PostPosted: 22:31 - 29 Nov 2013    Post subject: Re: Stupid newbie questions Reply with quote
id give a little more thought and ask if its a slope leading to the garage or if its on a flat. my garage is on a level floor so i pull p opposite and once door is open just walk it in. to take out, walk it back and 3 point turn it.
BUT
if you have a sloped driveway access to the garage id reverse order. if i park outside my house on the road, even the camber can be a bugger to push the bike backwards against the slope so 3 point first freewheel it back so when you start it up you ride up the slope rather than try push a bike backwards uphill. its not as easy.
zzr600
-Matt-
PostPosted: 22:37 - 29 Nov 2013    Post subject: Reply with quote
1. Never paid and never intend to. Most carparks and town centres have designates motorcycle bays, even a lot of barriered ones you can scoot around. Often do leave it on the pavement in quieter areas to access lamp-posts for chaining it to also but you can run the risk of a ticket in many cases then although ive yet to get one.
2. Good clean before and after winter. Acf50 everywhere except tyres and brakes etc before. If you ride dry salted roads i tend to leave it all winter, especially if you store in a dryish damp free garage. If riding in the wet through winter a lot maybe give the odd wash and reapply of ACF-50.
3. Tend to sit on mine and turn although sometimes on an angle you might need to get off and give it a push.
4. If you have a garage and power supply id get a trickle charger. You can attach a pigtail lead onto it and hang it just outside the fairing then easily connect it up for charging whenever you need. Particularly good idea besides bringing it in doors for a charge if you have periods you dont ride or commute a short distance.
neilthewolf
PostPosted: 18:06 - 01 Dec 2013    Post subject: Reply with quote
Great, thanks for all the replies
Neil
The last post was made 12 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 55.41 Kb
